Question about Samsung Xpress SL-C410W Laser Printer - Color - 2400 x 600 dpi Print - Plain Paper Print - Desktop 19 ppm Mono / 4 ppm Color Print - 150 sheets Input - Manual Duplex Print - Fast Ethernet - Wireless LAN - USB
Why are all lights on top are flashing, buttons not responsive and won't print?
All diagnostics say working fine, updated firmware and drivers.
  • Samsung Master
  • 1,316 Answers
The toner cartridge is empty,or you after refill the toner not change the toner chip.
Posted on Mar 31, 2019
SOURCE:
MF4150-All Panel lights remain ON and no response with any other button on display and Start and Stop/Reset button light also remains ON.
Support ' Support Laser Printers - imageCLASS ... - Canon
https://www.usa.canon.com/.../printers/...laser-printers-imagec...
Canon Inc.The imageCLASS MF8380Cdw delivers fast and accurate printing in approximately 14.3 seconds with Canon's Quick First Print Technology. Multi-page ...Missing: mf4150 ‎panel ‎remain ‎response
Amazon.com: Customer Questions & Answers
www.amazon.com/ask/questions/asin/B000J4J70Q
Amazon.com, Inc.Canon imageCLASS MF4150 Laser Duplex P/s/c/f 21PPM Adf ... make a two side
Feb 05, 2016 | Canon imageCLASS MF4150 All-In-One Laser...
How to up date hp Officejet 6700 Primium all-in-one code auf8437ojde38
  1. Switch on the HP Officejet 6700 series printer and wait until the printer is READY. [The Power light should be on]
  2. Double click on OJ6700_R1435A.exe to launch the HP Printer Update utility. A list of OfficeJet 6700 Premium series printers detected will be displayed on the screen.
    Note: If the Wired network printer you wish to upgrade is not displayed in the detected printer list, click on the Refresh button to scan for printers connected via the wired network.
  3. Click on the checkboxes on the left to select single or multiple OfficeJet 6700 series printers you wish to upgrade.
  4. Click on the Update button to start the firmware flashing process.
  5. Message showing "The selected printer has been updated successfully" will be displayed. Firmware flashing will begin.
    CAUTION! Do not interrupt the printer during the upgrade process. Printer may be damaged if power is interrupted during the firmware upgrade process.
  6. When the printer has successfully completed the flashing process, it will automatically print out a Self Test Diagnostic Page, that will show the new firmware version.
  7. Click on the Done button to close the HP Printer Update utility.
HP Officejet 6700 Premium All in One Firmware
Nov 14, 2014 | HP OfficeJet 6700 Premium All-in-One...
SP35 cards not printing more than one colour
Check to see if you have the current firmware installed on the printer. You can discover the version by going to Start > All Programs > Datacard Card Printers > Datacard Printer. Look at the bottom of the of the dialog box [Printer Toolbox] for the number following Printer Firmware Version. The number should be above version 24.49.
Datacard released a a new ribbon model that includes a new RFID chip. Printers with the older firmware will not recognize the new chip and thus think the ribbon is black only.
  1. Update the firmware by going to the Datacard website and use the search function in the top right corner of the website.
  2. Enter the search string "SP35 Firmware" one of the top links will point you the the Driver and Support page.
  3. Once the page loads, scroll down to the firmware subsection.
  4. Click on the "Begin your Go Green firmware upgrade now" link.
  5. Enter the contact info and click submit.
  6. Click download link once page loads.
  7. Open or Run download.
    1. This program will install software on the computer to update printer to new version of firmware. After the firmware is updated the program will ask if you would like to uninstall at end.
  8. A new dialog window will display Card printer Firmware Update.
  9. Select from drop down the Datacard printer that requires a firmware update.
  10. The dialog box will either display the update firmware version that can be flashed or indicate the "printer contains the latest firmware."
  11. If a update is possible click the Update button in the bottom left corner of the dialog window.
    1. Do Not Disconnect the power during the flash process.
    2. The printer will make beeps while the printer is flashing, this is normal.
  12. Wait till you hear the printer perform it's start-up sequence and you see a dialog on screen for success.
  13. Open Printer toolbox as mentioned above and review the firmware version number in the bottom left corner. Notice it should be a number greater than 24.49.
  14. Click on the Supplies tab in the printer toolbox dialog window and review the ribbon type.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/chance_d7833922a926e54f
Apr 10, 2014 | Datacard SP35 Printer
Lenovo r61e thinkpad wireless won't come on
Well there are many reasons but from what you've
said it can only be the Switch itself or your Router's
Firmware needs to be updated.
Go to Start: Type cmd in the command prompt Type
ipconfig press Enter look for the default gateway that's
your Routers IP Type the IP number into your Browsers
url or address bar press Enter. Once inside your Router
or Modem/Router view tabs and look for Update Firmware
Follow Prompts If this does not fix your problem then you
must further look into the Wireless Switch the Light is the
Switches Confirmation that it is Working Properly. Also
a
Driver will not cause this Function to not work and I know
you said the Drivers are Good and pls don't be Mad but has
the Adapter been Enabled with the Assumption your Computer has an RJ45 port for hard wiring.
Stay Positive and We'll Figure this Out.
Jul 20, 2017 | Lenovo ThinkPad R61e Notebook
I have a HP office jet L7500 it has worked fine and has no problem printing any of my emails or Word document but when I try to print a photo from my PICTURES stored in Windows Vista the yellow light...
If the printer is asking for firmware update, there is an update available on HP website. Click on the download button below to download.
Download the update and install it. turn off the printer after the update is installed and power on and try to print.
Download the firmware
*Note : If you have setup the printer on router/network, my suggestion would be to connect the printer using USB cable and do the firmware update for better results.
Oct 23, 2010 | HP Office Equipment & Supplies
Netgear wgps606 problems; updated firmware via
If the power light of WGps606 is flashing that means your AP is faulty, ig you try to hard reset it and powercycle it for 1 min.
if the light is still flashing thn this is a faulty unit.
If u hv warranty on it call Netgear - 1888-NETGEAR for replacement
or if u dont have warranty then go a new unit./
Regards
TecKC
Dec 13, 2009 | NetGear WGPS606 (WGPS606NAR) Print Server
My CD RW drive is not reading any CD
Here is the download page for the firmware update for this drive:
follow these instructions carefully.
8240firm119.exe
(free registration required at Driver Guide)
Firmware v1.19 for the LG GCE-8240B burner. After downloading double-click the file to start the extraction program. Accept the default unzip folder (C \8240firm119) then click the UNZIP button. 2 files will be written to the folder. One is the firmware (the exe file) and the other is a instructions.txt file. Be sure to read/print the instructions before attempting to use the firmware upgrade. Paying particular attention to the section dealing with whether your drive is OEM or LG. This firmware is only for LG drives and will not work on LG OEM drives. Use this file at your own risk. I nor driverguide.com will not assume any responsibility if your drive is damaged.
We are NOT responsible for any mistakes you make or you loosing power during the flash. You should be on a battery backup power supply to ensure you do not loose power.
Regards,
Worldvet
Aug 19, 2008 | LG GCE 8240B CD-RW Burner
Won't print - just flashes it's lights at me!
I tried what phrek said (" Pressing the flashing buttons simultaneously, evokes the printer to spit out an internal diagnostic page ..."), but after the diagnostic page printed out the printer worked fine again.
Thanks for the help, and hopefully things work out for the rest of you as well.
Aug 06, 2008 | HP PSC 1510 All-In-One InkJet Printer
Light flashing printer no print
unplug the (USB or Parallel) cable of the Printer from Printer backside which is connected to the Computer
open the top lid of the printer and check whether the carriage comes to middle or not?
It it moves automatically, then its fine.
Check the cartridges.
click the URL Link giveb below it will open a webpage. If it does not open a webpage then please copy the entire link and paste it in the address bar of the internet browser and click on "GO"
HP Deskjet 800 Series Printers - Fixing Blinking Lights
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpd09169&cc=us&lc=en&dlc=en&product=59305&dlc=en&lang=en
HP Deskjets - What are the front panel lights and buttons on the 800 series printers?
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpd09133&cc=us&lc=en&dlc=en&product=59305&dlc=en&lang=en
Check the End of warranty date on both the cartridges.
Deskjet 882c printer does not support reserve mode printing.
Means, even if only cartridge is defective or expired the printer will not print with other cartridge which is fine.
Both the cartridges should in inwarranty and fine.
Shake the cartridges well
With the color and black cartridges touch a clean, slightly damp cloth (squeeze out excess water),
to the printer nozzle area on the print cartridge, to see if you can make the ink flow freely.
Be careful not to touch the nozzle area (with holes on it) on the cartridges.
Wipe the copper-colored electrical contacts with a clean distilled water or clean tap water and then with a dry lint-free cotton cloth
Also using a new swab, clean the electrical contacts inside the printer, in the carriage.
Install both the cartirdges in the printer, disconnect the printer from the computer and try to print a self test and diagnostic page
Running a sample page
Turn the printer on.
Press and hold the RESUME button until the printer starts printing.
Release the RESUME button.
Running a diagnostic test
Press and hold the POWER button.
Press the RESUME button four times.
Release the POWER button.
Nov 20, 2007 | HP DeskJet 882c InkJet Printer
Samsung Xpress SL-C410W Laser Printer - Color - 2400 x 600 dpi Print - Plain Paper Print - Desktop 19 ppm Mono / 4 ppm Color Print - 150 sheets Input - Manual Duplex Print - Fast Ethernet - Wireless LAN - USB Logo
157 people viewed this question
Top Samsung Office Equipment & Supplies Experts
jasbo
jasbo
Steve Allison
Steve Allison
Lawrence Singapore
Level 1 Expert
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
