TRY TV MENU ON SIDE WILL NOT LET ME IN SETUP TO PROG. CABLE CHANNELS
SOURCE: LG RU-27FB30C. It's blocked.
http://www.newtvremotes.com/Mfrs/Zenith/ZenithTV/LP702.htm
VISIT THE ABOVE LINK AND ALSO SEARCH
RU-27FB30C on internet and you will get the manual
SOURCE: I don't have cable, so I bought a small antenna to
It's all digital now - don't forget.
You need to switch from cabel to antenna first.
Play around with menus - it has to be there. Or just do areset if there.
SOURCE: I have a brand new straight from box LG TV model
HDMI sends video from a source likea bluray player or 'cable box' to tv it will not send signal so you can program channels from it
turn tv to the HDMI input you plugged device into and watch cideo from that source
you will need to connect some type of antenna to be able to program channels on tv
very few tvs need channels programmed these days since most people hook up a cable or sattelite receiver and change channels that way
hope this helps if not give me more speecific details and i can help you more
good luck
SOURCE: My remote scanned all the
U are recieving an using DTV Free AIR broadcasting tv signal wright,get a better antena like a roof or a newly design digital antena for uses.This problems dose not happen to cable or sattellite services,i know this because their broadcasting tv signal frequencies are very strong and very high ranges of a broadcasting signal output for their recieving boxes.
SOURCE: 52LG50 lcd tv has white screen will not respond to remote
You will need to take it to a qualified tech to have it diagnosed. Without looking at the set, it sounds like a T-Con board issue
probably its on hotel mode, that model have a tablet in back with a f conector, 2 screews and release that tablet for a 2 inches,NOT ALL , then the menu for automatic searching will work, do not put that tablet again in place
