Reset Sanyo Tv without remote
Keep pressing the {MUTE} button until the TV powers on with the Service Menu displayed. Use the {CH+} {CH-} buttons to select menus. Use the {VOL+} {VOL -} buttons to change settings. Some menus might have sub-addresses. https://hardmasterreset.com/how-to-reset-sanyo-tv/
Use a pointed object (like a ballpoint pen) to press and hold theRESETbutton for 2-3 seconds.
After 2-3 seconds has elapsed, release theRESETbutton.
Initialize or Reset option(s) in the camera menus
The menu layout is different between cameras so check the operating instructions.
In general, there will be aResetorInitializesection within the menus of the camera.
Some cameras allow for resetting or initializing different options such as wireless settings, the settings used in taking the last picture, or all settings. Be sure to look at all available options in the product manual.
Manual reset process
Cameras manufactured prior to the year 2000 do not have reset buttons or options in the menus. Follow the steps below to reset:
Turn off the camera.
Remove the battery pack.
Remove the button-sized lithium battery.
Allow the camera to remain without power for 30 seconds.
Reinsert the button-sized lithium battery.
Reinsert the battery pack.
Turn on the camera.
NOTE: If your camera is experiencing an issue and it is not resolved by performing the appropriate reset or initialize procedure above, service may be required.
In camera settings menu, on the bottom of the screen you find Settings. In Settings is the only reset the camera knows. You only will reset the menus and shooting options. Date, time, language and video output settings are not reset.
If your camera has serious trouble, accessing menus or something like that, there is nothing like pressing a button for several seconds and everything will be ok. (not in the manual)
If you mean the password to the menus, please access the Web Server of your printer by entering the IP address on your browser. Once the web server is accessed, click on Settings > Security > Access Controls, make "No Security" is selected on all Menus.
The above is the description page for you Lexmark printer.
Solution
Some menus on the X8310 and X8350 are repeated in the Copy Mode, Scan Mode, Fax Mode and Photo Card menus.
If you press the Menu button while in any of the above menus, two ancillary menus will be listed, Maintenance and Device Defaults. To select either of these menus, press the check mark at the center of the navigation keys on the printer. Maintenance
Menu options
View Ink LevelsClean CartridgesAlign CartridgesPrint Test PageReset Defaults Device Defaults
Menu options
Set Date and Time Language Country Copy PaperPhoto PaperPhoto SizeButton BeepPower SaveTimeoutCaller ID Pattern ---
The ink levels should reset when the ink jet cartridge is installed.
Go to Canon.com under support call repairs for price on repair. If too costly, possible to sell for as is parts on a site like Ebay. Possibly you can reset the menus which may make a difference. Reset menus to factory or default.
I don't know this message, and am going to guess what can be done. I searched on the Olympus site for such a message, none. Not sure what it means.
I believe this has to do with a setting in the menus. Turn the camera on, go to the menus and set all to factory default, or something like that such as reset or reset all.
Test the camera after setting and set the menus to what you want.
There definitely must be a setting to reset the fuser counter. I cant tell you where to look as I am not familiar enough with that model. Check in the counter menus or the maintenance menus, or a reset menu.
