Brewing head, filter holder and filter sieve have been cleaned and sieve screwed firmly back into place
SOURCE: B60 is not operating properly
I had the same problem and it turned out to be the pressure safety kicking in. The bottom hole didn't punch through on the K-cup. Check to make sure that is not the problem.
SOURCE: I was trying to clean
I think the main problem with this machine is that the grounds fly all over inside when grinding and combine with the steam and hot water and eventually gum up the moving parts. This causes the latch for the filter basket to lose its grip sometimes and the door pops open during the brewing cycle...I was trying to take apart the slides to clean them out and made the mistake of removing the small screw underneath the left slide. Then the spring popped out and it took about an hour to get it back together, very frustrating. I ended up bending one end of the spring into a slight hook with a needle nose pliers so it would catch better on the "nub" that is connected to the side button. The best way I figured out to clean the slides so far is to blast them out with compressed air periodically for preventative maintenance. I use one of those cans normally used to dust off electronics and insert the straw into the slides.
SOURCE: Keurig starts & stops without brewing coffee, just descaled
The pic is clogged with coffee or the air bladder is bad. Use the tool on the underside of the tray to clean out pic. If that doesn't work, the bladder will be bad.
SOURCE: My Keurig B60 is inconsistant
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
