Heating & Cooling Logo
Jack Merritt Posted on Jan 04, 2016
Wireing on a GMP075-3 goodman furnace
2 red wired cam disconected in transport I beleive they came of the capacitor but not sure wich one goes where
Vongrayson
Level 1:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Contributor 25 Answers
  • Posted on Oct 15, 2019
Vongrayson
Contributor
Level 1:
Greenhorn:
Cheetah:
Answers
25
Questions
0
Helped
14494
Points
32
You need to have it done it will be about $30 with a handyman.
5 Related Answers
carldc3
carl carpenter
  • 82 Answers
  • Posted on Jan 23, 2009
SOURCE: I NED TO CONECT 3-1 RELAY OVERLOAD CAPACITOR IN MI FRIDGE
first take all the relays and capacitor off of compressor , then attach black wire with terminal on "C" terminal post usually top terminal, white wire with terminal goes on "S" terminal post on compressor, red wire with terminal goes on "R" terminal post on compressor. then take the two black wires one connects to white neutral wire and the other connects to the black power wire if tis fridge has a condensor fan then you will also need to connect it two the two black wires also thanks hope this helps
Don Berry
  • 230 Answers
  • Posted on Jan 29, 2009
SOURCE: goodman gms9090 furnace
Based on your description I would guess that there is a "leak" somewhere between the gas valve and the actual fire. Use soap bubbles to check the connections at the gas valve. Also check the gaskets in the Gas valve the same way. Lastly there may be a cracked or misaligned burner causing the "leak". Best of Luck!
Anonymous
  • 61 Answers
  • Posted on Feb 01, 2009
SOURCE: Goodman furnace GMPN080-4 Getting 4 RED blinks/Open Limit Swtch
You have a limit switch located in the furnace (a little bigger than a dime and located near the center of the front panel, sometimes the switch is mounted to a small fiberglass board) . There will be two wires going to it. They sometimes trip so often that they fail to automatically reset(due to dirty filters or undersized ductwork). You can SHUT OFF POWER TO THE FURNACE, then remove the two screws holding the switch in the furnace, pull the switch out of the furnace and tap on it and wipe it off.
The switch may work a few more times but should be replaced with the same size and type. You will see some rating printed on the switch somewhere. Write down all the numbers and get a replacemet from a furnace/AC supply house. If you have a meter and know how to use it you could check the switch for continuity.
Sometimes just a tap on the switch will get it going. There will also be a couple of rollout switches that could be tripped. They have little buttons on them to reset them. If they trip it may have other issues to be solved.
Hope this helps!
Matt
Lou Barta
  • 189 Answers
  • Posted on Apr 10, 2009
SOURCE: Old mercury thermostat, New furnace wiring issues
Two wire hookup on the old thermostat tells me that it was set up for heating only. You will most likely need a modern thermostat. But in the meantime try this with the old one. The two red wires on the furnace are probably Rh & Rc. If so these can be put "together" on the R terminal on the old stat. The two W's on the new furnace are probably W1 &v W2 This is for first and second stage heat. You can put the two "together" on the W terminal on the old stat. Do not hook up the greens (blower fan wires). Do not hook up the blue wires (They would go to the Y terminal on a modern stat for airconditioning.
Who ever sold you the furnace should have offered you a new thermostat.
Good luck....
Anonymous
  • 614 Answers
  • Posted on Jun 03, 2009
SOURCE: Goodman CK36-18: Outside fan kicks on, but
Sounds like a bad capacitor. They can be bad and the fan will still run. Turn off power and check for burnt wires on the top of the contactor going to the capacitor or on the top of the capacitor.. Check terminals on the compressor also. When capacitors go bad they are slightly swollen. They can also look good and be bad . Could be compressor but start with capacitir and wires. IWork on a lot goodman units. Most of the time it is the cap.
I was replacing my thermostat connected to my Goodman furnace. I must have mixed up the wires because I am not getting a read out on either the new or the old thermostat. I have electricity at the...
If you did not turn off power to the air handler the transformer shorted out.
Otherwise,red goes to r/rc,green goes to G,yellow goes to Y,white goes to W/W1,orange goes to O,black and or blue goes to Common.(C)
The dog chewed the wiring to the condesor outside. i re wired and now the furnace turns on but not the a/c unit ouside?
Hi, well you have 1/2 of it right. Recheck the wiring and wire it color to color as you are not getting 24 volts to the condenser. If you have a gas furnace and not a heat pump you will only need 2- wires to run the outdoor unit, red and yellow. Make sure the dog didn't chew through another section also.
Shastalaker7
Hi Proper way on wiring furnace.
I can give you a start, For heat only, R terminal on furnace to Red wire to R or RH terminal on thermostat. W terminal to White wire to W terminal on thermostat. G terminal to Green wire to G terminal on thermostat. This will get you heat but not air conditioning.
Goodman furnace
double check your wiring. R terminal on the furnace will provide 24 volts to the t-stat. W terminal in the t-stat will send 24 volts back to the furnace W terminal to turn on the heat. G terminal in the t-stat will send power to the G terminal in the furnace when the t-stat is switched to fan on. Y terminal in the t-stat will send power to the Y terminal in the furnace which in turn will send 24 volts to the A/C outside. The C terminal in the furnace should be connected to the c terminal in the A/C outside as well as to the T-stat. Check the fuse again
2answers
Problems with low voltage control wiring turning on cond. unit
Only 2 wires going outside.
Yellow from the thermostat and the common wire from the lv side of the transformer.
New furnace, goodman and reinstalling squirrel cage... unsure where to put red wire running from squirrel cage
Follow your schematic on the new unit. It will tell you where the wire goes. Some of the "extra" wires are connected to the main board close to where the "used" wires are and they are labled "spare". Find the blower motor on the schematic and trace out where this wire will go.
I have a Goodman furnace GMPN080-4 REV B. I had the blower motor take a dive, so I replaced it with another equivalent 115 VAC 60 Hz 1/2 HP motor. I replaced the 10.0 MFD +10% -5% capacitor with a 7.5 MFD...
limit switch is on the heat exchanger black plastic about 1and1/2 in. by 2 in. with 2 wires going to it , it has 2 screws holding it in take it out and check it with an ohm meter and you should not have a reading if it is good
Furance lights and goes out after ten seconds does this three times.bought a new flame sensor worked two days same thing again.goodman furnace
If it isnt the flame sensor make sure the furnace ground wire is hooked up.If the ground is bad it cant sense flame.
2answers
Goodman GMP100-5 Rev Furnace Manual
I don't know where you are located, but there is a Goodman distributor in Sacramento, CA. Also in Ontario CA. They are a distributor so they may be able to help you or tell where to find someone who will help. Goodman is also known as GMC or Janitrol.
Top Goodman Heating & Cooling Experts
Paul Carew
Mike Cairns
Mike Cairns
Jay Finke
Jay Finke
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
