SOURCE: LAND ROVER DISCOVERI 1995
The radio codes are only available from the dealer, you will need to goto your nearest dealer with your registration, they will type your vin# in there system and give you the code.
hope this helps
JPTCAT
SOURCE: 1995 Range Rover Land Rover Questions
the back windshield is the front windshield one just pull it front or back not up all down
hope is helps
Jamie
SOURCE: land rover rear axle
The pinion bearing preload should be 3 Nm on a pull scale with the side shafts removed.
SOURCE: 2004 land rover discovery, ignition
it sounds like your starter motor is faulty. first make sure the battery is fully charged, then place a screwdriver between the contacts of the solenoid on the starter motor, if it again just clicks, then you need to repair or replace the starter motor.
hope this helps
