"MATH", "APPS", "PRGM" & "VARS" keys do not function either (same row on PWB).
SOURCE: My TI-89 row of keys not working
At least it was the enter key. the other key can be gotten using the catalog. I'm not even sure taking it apart would help. I've seen one person do it and it wasn't pretty. Another person destroyed his. If you can program you can work around the bad keys but, could be a nightmare unless your only simply adding. Sorry! Hopefully it will come back w/ normal use.
SOURCE: The math operation keys +,-, etc)on my TI84 aren't
Try reinstalling, might be memory got used up
SOURCE: all of my apps, gone !
Please do not dislike your math teacher, for your own sake: You will not learn much from someone whom you dislike. Now Relax.
All the applications that were preloaded in your calculator are available to download freely from http://education.ti.com Use the tab Download--> Apps and software. Then select software for the TI83/TI84 Family. While you are at the site download the TI Connect, if yoy do not have it already. The link follows.
http://education.ti.com/educationportal/sites/US/productDetail/us_ti_connect.html You can also download the latest OS there.
Install TI connect on your computer and run it to open the main Window.Then connect you calculator to a USB port and, in the TIConnect main window Click the TIDeviceInfo icon. Software will try to retrieve the info. If it does your calculator is ready to communicate with the computer.
If it tells you Device Not found , Click communication settings in same pop up window where it said Not found, and Select Device, Select Cable (USB or TIsilver cable), Select Port (USB1) and Click OK..
If you are lucky and it works, you can reinstall the OS, which can be downloaded from education.ti.com. You drag and drop the OS on the TIconnect main window. Calculator must of couse be connected to computer. To install an application already downloaded to you computer, drag it to the main window of TI Connect and drop it. Keep installing, the appilcations you want.
If you have problem with TIconnect, use the calc-to-calc cable to transfer the Apps on a working calculator. Yous should be on Receive mode [2nd][Link] --->>Receive. (When both calculators are ready hit enter.) The other calculator, you guessed exactly right, must be on Send [2nd][Link][SEND][C:Apps]. A list of Apps appears. Scroll down the list. If you want to transmit un app you press [ENTER] when the arrow reaches its line. Once an app is selected , a small square appears on the left. After the selection, Hit transmit. I suggest you transfer Apps, one after the other. Avoid selecting them all and send them all at one go.
Hope it helps
Testimonial: "i'll try not to hold a grudge against my math teacher lol THANK YOU SO MUCH!"
SOURCE: My calculator turnd on, but when I press 1,2,3...
Need to set your brightness setting . Press 2nd and the up or down arrow key this should darken the curser and the display to where you can see it .
SOURCE: Have a row of keys that do not work (possible
Here are your options
1. Remove and REPLACE batteries....
2. Reformat the Calculator. Games, hacks and other things can make buttons not function properly.
(If you or he/she has important info or saved data on the calculator, Archive it first then reformat)
3.Return to store UNLESS the box/instructions/calculator says to return to Texas Instruments then don't take it to the store. Send it in.
4. Lastly if you think water damage has occurred to the buttons then put it in a container with silica gel for a few days to remove any water and. If you feeling tech savvy enough then open it up and clean the water residue off the buttons. The water can not "break" the buttons but it can get in the way of the button cell contacts... and it needs to be cleaned out.
