SOURCE: Can i connect my Sharp flatscreen tv to my wifi
Ron, in order to connect your TV to your home network, it will need an network interface. A network interface can be either a wired network jack on the TV itself, or a built in wireless capability (WiFi). You didn't provide the model number of your particular Sharp TV, so I can't tell you if your TV offers this connectivity or not.
Even if your TV offers wired or wireless connectivity, some TVs only allow network access to update firmware or to display "still" JPEG or GIF images; not to stream audio or video. The TV will need to have some sort of player to display or play video and / or audio files. Even then, if the TV is not fairly new enough, it may lack the support for newer file formats - such as .MKV, MPEG, etc. that are used for a large number of HD content.
You can get around this hurdle by connecting a newer computer to the TV. Purchase a wireless keyboard & mouse and connect the computer's video card to the TV so that it will appear as a monitor to the computer. Make sure your get a video card in the computer that will provide a digital video output - (HDMI, DVI, etc.) and a cable that can plug into one of the unused A/V inputs on the TV. If using a cable other then HDMI, you'll need to provide a cable between the computer's audio output and the TV's audio input. Use the computer's network interface to download or stream a program directly to your 55 inch "monitor".
I hope this helps - good luck!
SOURCE: I just bought a new TCL 55'inch smart TV. When I
Contact the authorized service center immediately. The set is not perfect in terms of Wi-Fi. http://electronicshelponline.blogspot.com/
SOURCE: I have a 55 inch rca led smart tv how can I download apps to my tv
It needs an internet connection.either wifi or Ethernet.then you will be able to choose from the menu within the set.If it's android you can look for googleplay.if it's toshiba or independent make it may run on a Linux o.s.which means you need to use it's built in browser to download or use URL of Internet addresses.
most nowadays are android based o.s. So it's googleplay for apps for which you need a gmail account which is free and easy to create.
make sure that you change the channels both to the right setting on your television and your romote and also replacee the batteries in the romote
