Texas Instruments TI-30XA Calculator Logo
Debra Guevara Posted on Dec 01, 2015
Turns on but some of the outline of the numbers don't show on screen.
TV Screen is orange
In order to TRY to assist you I need the brand and model number.
1helpful
I hit something on my camera that each time I take a picture, the preview is a tiny picture in the upper left screen and there are yellow outlines around areas of the picture and in the lower right corner,...
when you are in the playback mode, you can use the zoom function (as you use it when you take a picture), this will zoom into the image you took.
the yellow frame show you where you are in the full image.
1helpful
My Sony KP-53S35 turns on, shows a blue screen, turns off
It sounds like the blue CRT (picture tube) is failing. The part number for this is 8-733-575-25 but you will need a technician to replace it for you as there is mechanical and electrical alignment to with with it. At that point it probably isn't cost effective to repair the TV. Please take a few moments to rate my answer. Thank you.
I have a 61'' Panasonic tv that is showing green and red outlines around the figures on the screen. It originally started as just green outlines. Any ideas on what the problem is would be great. Thanks
The convergence is off. The convergence is basically the assimilation of the image on the screen from the three "guns" behind the screen. There should be a menu option to align the convergence in the image portion of the menu. If this does not fix the issue, then your convergence chip might be on it's last leg.
Canon ixus 500 turns on beeps 4 times,shows E18 on the bottom left of thelcd screen and then turns itself off.
The following blog outlines some repair options for an E18 lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
May 25, 2008 • Cameras
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Jerry Naidoo
Paul Bade
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
