HP Officejet Pro 8600 Logo
L
Linda Posted on Nov 04, 2015
I cannot copy or scan
When I put in paper to copy or scan all that prints are lines no words.
5 Related Answers
Anonymous
  • Posted on Oct 02, 2008
SOURCE: Printer will copy and scan but will not print anything from internet
copi driver instal to my computer
Anonymous
  • 62 Answers
  • Posted on Feb 12, 2009
SOURCE: 2 vertical, parallel, black, lines print on copy
Sounds like it could be bad cartridge or scanner. Try replacing cartridge first cause this is pretty easy to do and is alot cheaper.
jonb3838
John Cole
  • 237 Answers
SOURCE: HP Laserjet 3390 Prints a Black Line on papers
make sure you check and make certain there are no scratches clean both the top of the scanner and the scanner bed itself and wipe down with a lint free cloth
millstones
  • 59 Answers
  • Posted on Mar 23, 2009
SOURCE: there is a line on the paper when copying on our hp 7680
Is the line apparent when you do a copy off the glass flat or when you copy through the auto sheet feeder?
Lift up the document feeder so you can see the glass. Have a look at the glass can you see and signs of tippex of other stuff on the glass, give the glass a clean and the line should go. If not there may be dust etc inside the optical mechanism.
Anonymous
  • 53 Answers
  • Posted on May 19, 2009
SOURCE: Lines print on copies when put through the scanner. But do not appear on copies when placed on the glass
You may also want to check if the ADF is dirty or contaminated with dust or hair. Here's a link with some information about how to clean the scanner:
http://support.lexmark.com:80/perl/support/support.cgi?relevance=1&ccs=229:1:0:111:0:0&mode=DOCS&doctype=KB&term=Scan%20Copy%20Quality&docid=ENUS32544
2answers
How do I reduce a page being copied?
scan a copy to pc documents , save to word , use photo shop and reduce in size
print page and then re-scan
We have a Canon Image Class MF5900. When we put items through the feeder on the top of the machine to feed through for either copying or scanning we get the copies/scans but they also have line through...
Yes, this machine has what the call a scanning glass.Its the small thin glass where the paper goes down through the doc feed.its on this glass. A real close visual or take a clean piece of paper. Wad it up a and clean glass with that paper. It works. But if you don't have a line when you print or from the platin.(glass,main).its on that reader glass.
How do I print a mirror image from canon pixma MG5250 mirror image?
In the printer driver settings, where you can select the paper type, you have to choose "other paper" and select "T-Shirt Transfer".
2answers
I have a Ricoh Aficio 1013 that prints fine but copies are unclear and off
Problem Cause Solution Colored lines appear. The exposure glass or scanning glass is dirty. Clean them. See "Maintaining Your Machine", About this Machine . Copies appear dirty. Image density is too high. Adjust the image density settings. See "Adjusting Copy Image Density", Copy and Document Server Reference . Copies appear dirty. Auto Image Density is not selected. On the control panel, select [Auto Density]. The reverse side of an original image is copied. Image density is too high. Adjust the image density settings. See "Adjusting Copy Image Density", Copy and Document Server Reference . The reverse side of an original image is copied. Auto Image Density is not selected. On the control panel, select [Auto Density]. A shadow appears on copies if you use pasted originals. Image density is too high.
  • Adjust the image density settings. See "Adjusting Copy Image Density", Copy and Document Server Reference .
  • Change the orientation of the original.
  • Put mending tape on the pasted part.
The same copy area is dirty whenever making copies. The exposure glass, scanning glass, or ADF is dirty. Clean them. See "Maintaining Your Machine", About This Machine . The same copy area is dirty whenever making copies.
  • The original that has already been printed is scanned.
  • Original Type is set to [Text / Photo], and an original with text and photographs that can hardly be distinguished from each other is loaded.
On the control panel, press [Generation Copy], and then begin copying. Copies are too light. Image density is too light. Adjust the image density settings. See "Adjusting Copy Image Density", Copy and Document Server Reference . Copies are too light. A light copy may result when you use damp or rough grain paper. Use recommended paper only and be sure its storage environment meets the recommended temperature and humidity conditions. For details about recommended paper and the proper way to store it, see "Recommended Paper Sizes and Types" and "Paper Storage", About This Machine . Parts of images are not copied. The original is not set correctly. Set originals correctly. See "Placing Originals", Copy and Document Server Reference . Parts of images are not copied. The correct paper size is not selected. Select the proper paper size. Parts of images are not copied. Even if you place originals in the ADF correctly, margin of a few millimeters on all four sides of the original might not be copied. Use "Create Margin" function to reduce the image of its original size.
For details about missing image area, see "Missing Image Area", Copy and Document Server Reference . images appear only partially. The paper is damp. Use paper that has been stored in the recommended temperature and humidity condition. For details about the proper way to store it, see "Paper Storage", About This Machine . Black lines appear. The exposure glass or scanning glass is dirty. Clean them. See "Maintaining Your Machine", About This Machine . White lines appear. The exposure glass or scanning glass is dirty. Clean them. See "Maintaining Your Machine", About This Machine . White lines appear. The dustproof glass is dirty. Clean the dustproof glass. See "Cleaning the Dustproof Glass", About This Machine . Copies are blank. The original is not set correctly. When using the exposure glass, face the originals down. When using the ADF, face them up. A moir? pattern is produced on copies. Your original has a dot pattern image or many lines. Place the original on the exposure glass at a slight angle. Black spots appear on the copy of a photographic print. Because of high humidity, the photographic print has stuck to the exposure glass. Place the print on the exposure glass in either of the following ways:
  • Place an OHP transparency on the exposure glass, and then place the print on the OHP transparency.
  • Place the print on the exposure glass, and then place two or three sheets of white paper on it. Leave the ADF open when copying.
White stripes appear on the OHP. Fragments of paper are stuck to the OHP. Use a dry cloth to wipe any paper fragments off the back of the OHP. The image on the back side of duplex copies has mottled blank patches or is smudged. Missing patches and smudges are caused by moisture leaking from the paper.
  • Do not install the machine in areas that are susceptible to low temperatures.
  • Use paper that has been stored where temperature and humidity conditions meet the limitations we recommend. For details about the paper storage conditions we recommend, see "Paper Storage", About This Machine .
  • Install the Optional anti-humidity heater. For details about the anti-humidity heater, contact your service representative.
When You Cannot Make Clear Copies
My lexmark printer does not want to scan, when we tell it to scan it prints out a paper with blue lines,i have seen this before so i put it in the scanner and it scans that paper but when i put the paper i...
Make sure that you are pressing the Scan button and not the Copy button on the printer operator panel.
Try to re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
1helpful
2answers
When making copies using the ADF, vertical lines print out on the paper. Doesn't happen when paper put directly on the glass.
The ADF works by moving the paper past the scanhead, on glass works by moving scanhead past the paper.
When you are scanning with ADF, the scanhead is parked in a particular position, under the glass. Just at one extreme end. Open the unit to te point that you are able to clean the lint, debris, lollipop sticks from this area. That should be it, since works otherwise indicates a good scan head.
2helpful
2answers
The printer acts like it is printing, but doesnt actually print
uninstall ur printers driver and re-install it. This will deffinetly solve your problem but then also giving u a word of caution repair your windows Operating system. Its easy just put ur cd and do whatever it asks until repair comes and put it on repair option. your spool.exe is corrupt by virus
Black line down the paper on copy mode. Ok in print mode.
There is most likely something on your scan glass that is blocking the scanner. Clean of both pieces of glass that are there when you flip open the ADF, or top cover. Try to copy again. If it is still there then there is either something on the scanner piece that moves back and forth to scan or one of your scan LEDs is burnt out and the scanner will have to be replaced.
2answers
3050
when we copy or scan we get lines at both side throught
the paper
k24674
Grand Canyon Tech
Grand Canyon Tech
