SOURCE: rice cooker vs a crocpot/slow cooker
I have both and use both for different things. The rice cooker cooks faster than the slow cooker. What the Crockpot does really well, the rice cooker cannot do. For example, with the crock pot, you can buy less expensive cuts of meat and because of the slow cook method, they will be tender, juicy, and delicious. You can make soups, stews and casseroles in a crock pot and the great thing is that you can turn it on low, go to work, and when you come home, dinner is done. You can cook the same types of things in a rice cooker but you can't leave it all day. You CAN saute', fry, etc,. in your rice cooker which you can't do in a crock pot but for dense veggies and tougher cuts of meat, stew beef for example, there's no comparison. I have an Oster Rice Cooker and Steamer which I use nearly every day. I cook rice, obviously, casseroles, veggies, spaghetti and meatballs, all kinds of side dishes and soups in it. I use the crockpot several times a week but more often in the Fall and Winter when I make soups, stews, chilis, roasts and BBQ. Oh my gosh, you have to try BBQ Ribs in the crock pot! They melt in your mouth. Go to Yahoo! Groups. You'll find all kinds of great info for both your rice cooker and crock pot. I have one of the fancier, more expensive crock pots because I take it to work with me one day a week for lunch. The lid seals and it comes with a carrier. If you do most of your cooking at home, you can spend a little less and get a good one. I recommend getting one that has at least 3 heat settings though. Different foods require different temps. Happy Cooking!
SOURCE: Salton RA3 3-Cup Rice Cooker Question
Put equal amounts rice and water (up to 3 cups only) in liner pot, plug in, put lid on, flip little front switch. 10-15 minutes later it will be done and the pot will switch to "warm" mode by itself. Gently fluff with paddle before serving. You can also add salt or other seasonings to the water/rice mixture before starting.
SOURCE: Need instructions for National Rice-O-Mat Rice Cooker SR 10GHN
You can just go to a web site and look search for Rice Cooker Steamer. And find some important information.
SOURCE: Wolfgang Puck 7 cup rice cooker instruction manual missing
Here the standard manual : WOLFGANG
However you can read and print recipes online from their website , click below:
Rice Cooker Recipes Cookbook : Recipezaar
Rice Cooker Creations Cookbook
SOURCE: Need directions for Comet stove top rice cooker
Fill the bottom to the line with water. Put two cups of rice in the top and two cups of water. Put on stove top on high until lower water is boiling, turn to medium heat. For white rice check after about 20 minutes, if water is assorbed and rice is tender, fluff with a fork...eat. If it needs a few more minutes of cooking, no problem.
Brown rice will take about 45 minutes.
I have used my stove top cooker for at least 35 years...ordered it with box top and some money from Comet Rice.
Pat
