Your Display panel is out. You mite also have a major board problem, recommended that you get a Konica Minolta Tech to look at it. The panel do go out. the panel wear out after a while
If the machine fails to boot, it normally is a main board failure or a NVRAM failure. It would be best to contact a trained technician for this repair.
www.fixya.com > Forum > Printers & Copiers > Konica Minolta
Konica Minolta BizHub C252 - pale colors on the long side · Konica Minolta. ... I have a Konica C250 machine which cannot print red color at all. I had changed ...
www.fixyourownprinter.com/posts/40820
Aug 22, 2008 - On the right hand side of the drum (the part that has the large green handle) that easily slides out. There is a ..... I have konica minolta bizhub c252 colour printer. ... The K light came on a long time ago and is constant on now.
? 0:28
https://www.youtube.com/watch?v=eD8HdNq0MlE
Nov 23, 2011 - Uploaded by Tennants Nottingham
How to clean the drums/i units on the konica minolta number plate printer ... Fix or repair color laser printer with fading, lightprint, or lines samsung clp 300 ... Imaging Unit Reset for Konica Minolta Bizhub C203 / C253 / C353
sounds like the sleep timer is activating before the boot is finished try touching the screen and then switch the timer up or if it networked go to the machine web page and turn the timers up from there then try again
To change language: Press "Utility/Counter" Press number 2 key, then number 1, then number 1 again. This will get you to the language selection without having to read the screen. Once there select your language. If this does not correct the problem, you may have a board or Nav Ram problem and should contact someone for service.
CD231 at power up. Solution: CAUSE: Complete fax kit was not installed.
SOLUTION: These three items make up the complete fax kit, FK502, MK706 and MK704. If not installed together, the C250/C252 will display code CD231. hope that helps
