Mitsubishi WD-52525 52" Rear Projection HDTV Logo
Posted on Jul 13, 2009
The lamp light is still on after replacing the
The lamp light (gold not red) is still on after replacing the lamp. We have taken it out and replaced it and also have reset the TV several times, but light continues to stay on.
Anonymous
Level 1:
  • Contributor 64 Answers
  • Posted on Aug 01, 2009
Anonymous
Contributor
Level 1:
Answers
64
Questions
0
Helped
11813
Points
81
Plug the TV out of the wall. Wait. Plug it back in. Does it still stay on? If not, there is somethign wrong with your remote, or the TV circutiry is not shutting off. Try controlling the on/off via manually pushing the power button on the tv (both on and off).
1helpful
Ive just bought a new bulb for my projector (Optoma HD700X DLP Projector), taken the old one out and screwed this one in, but im still getting a read light when i turn it on, it sounds like it is...
Hello
if replacement lamp has done, was the lamp timer reset after replacement? and if the lamp is original, there is either a bad lamp or a cooling problem.
Good luck
I just replaced the lamps and the lamp 1 and lamp 2 lights are flashing red. the projector won't fire up.
The lamps are not in correctly. When the old lamps are taken out, it reveals two very small lever type switches that have to be down for the lamps to connect and for the projector to recognise the lamps. These switches can be seen in the section in between where the lamps go. They are about 4mm. Hope this helps. It happened to me.
HITACHI ULTRAVISION DIGITAL TV.MODEL NO: SP60WS lamp light is red
The lamp should be replace to fix the no picture since the lamp light is red.
Download the user's guide and see pages # 69-72 for lamp replacement.
1helpful
2helpful
2answers
Just replaced lamp. when plugged in, power light
hello make sure the lamp is fitted securely and the lamp cover aswell
regards
shaun
Replacement lamp - Mitsibushi
Did you get the lamp door back on properly? There is a switch that when the door is taken off the switch there keeps the set from coming on.
KDF-55W655
red light blinks in 5 times then pause and then repeats. It is the lamp error. " Lamp Driver Defect"
When the "LAMP-PORT" (pin 95) is low, the lamp is not turned on. If the "LAMP-HV-DET"(pin 96) is low at the same time, it is classified as no high voltage of the lamp driver. I'm guessing it needs a Lamp driver which I think is on the C Board, which is part of the "Optics Unit Block Assy. The C Board cannot be orderd separately, and Optics Unit Blocks are not cheap. Good luck
Bobby G aka poolmvp1
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
