Powermatic 2 Electric Cigarette Injector Machine Logo
Ray Mason Posted on Oct 18, 2015
Plastic end on injector broke where can you buy parts Power Matic II ?
Judi lena
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 15, 2019
Judi lena
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1567
Points
I'm trying to replace the cleaning tools for my topomatic rolling machine I lost them I have looked everywhere can you help me please
Frank Hunter
Level 1:
New Friend:
  • Contributor 30 Answers
  • Posted on May 02, 2016
Frank Hunter
Contributor
Level 1:
New Friend:
Answers
30
Questions
0
Helped
51575
Points
68
I called them or
pic your part here then call
http://www.powermaticinjector.com/c2instruct.asp
The shifter linkage broke at the tran , its the lil plastic ball joint that broke , do i have to change the hole cable/rod r is there a way to change the plastic ball piece ??????
Call your exPontiac dealer Buicks share a lot of parts with Pontiac, call the parts department an see if they have a fix, I imagine you'll have to buy a whole new cable. You can try a bone yard but you'll end up with the same thing eventually.
Where do i get the small plastic piece that slides back and forth in the track at the bottom of the power window? It holds the stud at the end of the regulator arm in the track. Mine broke into four...
Go to this site and poke around, they have never sent me a bad or wrong Saturn part.
http://www.trademotion.com/splash/index.cfm?siteid=214643
1helpful
Hi, I have a 1999 Camry LE 4-cylinder automatic. The car is not shifting into gear. I popped the hood up and noticed that the transmission control cable (shifter cable) connection to the neutral saftey...
I think the cable is molded into the little plastic piece. see if you can see the end of the cable. see if it looks like it broke, or was cut. if not, the molding came undone, and the cable pulled from the anchor in the plastic thing.
Plastic band broke at the end where pin goes ,is f...
Go to their web site http://www.fossil.com/en_US/shop/customer_care/static/fossil-orderlinks.html and you will arrive at a page with ordering info. on how to buy new bands.
May 14, 2010 • Watches
I broke the socket that plugs into the car. Where
Radio Shack, Fry's or any major audio electronics store. I have also seen them in Lowe's and Home Depot in CA. Make sure the in line fuse is the same size as your previous one. Don't buy the el-cheapo socket plugs... they will melt over time Buy hard plastic vs soft plastic type. A couple of dollars more is not worth the damage the soft plastic plugs can cause.
Kelly
2003 Honda Odyssey driver power seat cushion has two adjustments. One for the front to raise up and down and one for the back to raise up and down. From observation, there is a white plastic rod that is...
Honestly I am not familair with this item however, this rod ould appear to be a drive line, being plastic it may be reapirable with a $6 plastic repair kit, it is in a syringe that adds part1 and 2 then you mix it and let it set, it works very well, however, it broke for a reason, find out why first as this may be a futile effort.
Lastly, your Honda dealer or European dismantler should be able to supply this piece.
Good luck
1helpful
Need a replacement carafe for our elite maxi matic 10 cup coffee
I have the same coffee maker & mine carafe broke too, The Carafe is $10.95 incl. shipping & handling, you will need to call Maxi-Matic customer service @ 626-912-9877 & they will e-mail you a order form to fill out. Hope this help.
Broke plastic handle on fry cooker.
If you still have your manual to this unit I bet the manufacturer has a website that you can order from. If you don't have your manual then you can google the manufacturer for their website and order a new one there. I always keep my maunals for this reason. I hope this helps.
Top Powermatic Cooking Experts
ADMIN Andrew
ADMIN Andrew
Billie Aukuso
john h
Are you a Powermatic Cooking Expert? Answer questions, earn points and help others
