Which one is the IH POWER SUPPLY
Located behind the front panel right side below the control panel., controls the magnetic heating coil for the fuser.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: my customer has a bizhub di5510 copier that shuts down
If you can get schmatics diagrams of the machine locate which CB is breaking and then locate what units it feeds, such as fuser or HV ,LV supply boards etc Disconnect the board(s) assigned to that breaker see if it trips
SOURCE: I have a Konica Minolta
Did you turn "ON" the Main power switch "ON"? Also, you have to press the power switch "ON" that is on the side of the control panel.
SOURCE: my bizhub c351 has a
precission roller for parts is the best i have found... or call the dealer nearest you... probly spendy
