Question about Dryers
Why does my ceiling fan 897 only spin slowly - Dryers
  • Dryers Master
  • 26,370 Answers
If it has chain controls, one changes the direction, Clockwise, Counter clockwise. The other one alters the speed in 4 pulls, from OFF, SLOW SPEED, MEDIUM SPEED, FAST SPEED, and back to OFF. If there are three chains, the third turns the light on an off.
Posted on Sep 19, 2015
SOURCE:
My hunter ceiling fan turns very slow
Check your capacitor. If this is an add on remote, set the fan on high with the remote then pull the chain on the fan until you get high speed.
Sep 17, 2014 | Hunter 52" Ceiling Fan With Light And...
Hello, I replaced a light fixture on my existing Emerson ceiling fan. The light worked right away but the blades didn't turn. I could hear power going to the motor so I went back into the switch cup and...
Signs of a bad capacitor in a ceiling fan include:
  • Fan runs slowly or not at all on all speeds
  • Fan will not start but will spin if started by hand
  • Certain speeds are slow or do not work
  • The motor hums and turns freely by hand but will not spin
    The capacitor is usually a black box inside the switch housing of the fan. If this box appears burnt or melted in any way, that is also the sign of a bad capacitor and it should be replaced.
    have a good day !!
  • Feb 17, 2011 | Emerson Fans CF705AW 52" Northwind Ceiling
    Ceiling fan will not spin fast
    in england the usual house current is 220 volts and here the current is 120volts. this explains the problem. unless there is a switch to change your fan to a 110 current built in it might make sense to buy a new fan and move on. rewiring it would be expensive and unless it has alot of sentimental value probably not worth it.
    May 31, 2010 | Hampton Bay Dryers
    Ceiling fan does not blow air
    I would guess that the blades are on upside down. Ceiling fans are not supposed to work the same as desk fans though. The idea is not to create a strong flow of air but to create a "cooling breeze" by speeding the convection currents. They work better when they are running slowly (like you see in the old movies)
    Sep 19, 2009 | Hampton Bay 24002 Ceiling Fan
    New Hampton Bay ceiling fans spin too slow
    Slow spinning of the fan might be caused by a low voltage. Is there any way you can measure the voltage, and if the wires are properly connected, check for any loose wiring or rust in between connections. Maybe the breaker that supplies power to the fans has a loose connections inside, try putting a new breaker of same rated current. Check if those three fans are connected to the same breaker. Breaker can go bad from the inside not doing a proper connection and supplying a low voltage, this might be causing the slow spinning of the fan. Second the black box in the space with all the wires is called the capacitor.
    May 30, 2009 | Hampton Bay 24750 Huntington III Ceiling...
    Ceiling fan turns slowly
    If you've had it for a few years, the bearings are probably getting bad (dry).
    Always start a fan on high---then go to the speed you want, only the high speed windings will handle start-up.
    Apr 26, 2009 | Dryers
    Ceiling to low for this product =(
    hi! condenser is fault in fan! so only your fan run slowly! put high voltage condenser! then the run run fastly!
    Jul 10, 2008 | Hampton Bay AC434-WB 52'' Ponte Vecchio...
    Ceiling fan power
    It sounds like the fan motor has blown out. Is this an old fan? The motors do burn out every 5-10 years, depending on the brand and quality of motor.
    Apr 14, 2008 | Hampton Bay 73554 Antigua Ceiling Fan
    Dryers Logo
    164 people viewed this question
    Top Dryers Experts
    Marvin
    Marvin
    Craig Butler
    Craig Butler
