Watches Logo
R
Ron McQueen Posted on Sep 13, 2015
How to set the day of the week
Model# 0340
How can I change the days in casio Ef 331
First of all avoid setting the day and day of the week between 9.00 pm and 6.00 am. The day and day of the week may not change in the following day if you do.
Try this,
1) Pull the crown to the first click.
2) Set the day by rotating the crown counterclockwise.
3) Set the day of the week by rotating the crown clockwise.
4) Push the crown back to its normal position.
Hope this will help.
Cheers
2helpful
How to set the day on the timex, as i am able to set the date but i dont know how to set the day of the week in T46601-V1 model watch
it can only set by turning the time for 24 hour using the crown the day of the week changes every 3 AM, i hope i had helped you.
I was given a tommy hilfiger watch and I can't figure out how to set the day/date. its a analog watch with a digital day/date, light blue plastic strap and case with 3 nobs on side. center one when...
One of the twist setting knobs may also be a digital, try holding for 10 secs, then date will blink, use other kn9b to toggle up and down, then return original , press once to set.
7helpful
How to set an Armitron watch. Can't set the days correctly.
mcdevito75 here, The stem has 2 positions, Carefully slip a fingernail under the stem and lift, it may take a few trys to get used to it, in this first position you should be able to set the DATE very easily and Maybe the DAY of the wwek also, turn the stem 1 way to change the DATE and the other way For the DAY of the week., Let"s figure you can only set the DATE in this first position, First thig to do is set the DAY of the week, go thru the watches 24 hour cycle and set the DAY to 1 DAY before the DAY you need, now in that first position of the stem, set the DATE to 1 DATE before the DATE you need, now in the 2nd position we all know pull the stem out to set the time of day, go thru the 24 hour cycle to bring up the DAY of the week and DATE you need. Now your watch is set and will change on tome at around mid-nite.
Jul 21, 2010 • Watches
Setting Date & Day
Two clicks to the dial on the right. First click adjusts the day of the month. To change the day of the week pull out to second click and go forward or backward in 'time' and week will follow.
Apr 11, 2009 • Watches
1helpful
2answers
Can't set day of the week for armitron MD06117 mens watch
Purchased my Armitron men's digtal watch in 2009. Here's the twist on setting the name of the Day of the Week on my watch. When you get to the name of the Day of the Week flashing.. you don't get Su...Mo...Tu... You get 01..02..03... up through 99. (You think.. what the hell is this??) DON'T TRY TO SET Sun.. Mon.. etc here.. you won't find it. The puzzle solver..and it is.. IS TO SET THE LAST TWO DIGITS OF THE YEAR HERE.. Example... it is now 2010.. so scroll thru the numbers and set it to "10"!! Now.. when you go and set the numerical day date e.g. 3 for March, and set the numerical day - e.g. 15, the on-board computer?? in the watch will AUTOMATICALLY SET THE NAME OF THE WEEK!! It will look-up For Example.. in the year 2010.. 3-14 is SUN.. and will set it as that!! Hope this saves you some frustration. Regards... [email protected] (Mar 14, 2010)
5helpful
Question:how to set the weekday on a Fossil watch model BQ-9165.
You have to pull out the stem all the way and turn clockwise until you get to the correct day. Hopefully you won't have to wind thru the whole week.
Date setting of Frederique constant
hi
never change week or date when day is on "sun" or "mon" also never change date or week or day when time is between 9 pm and 5 am.
to change day, move time back and forth between 10 pm and 2 am.
moon will change only after 24 hr round (not during quick day change)
hope this helps
eli
Oct 17, 2008 • Watches
Top Invicta Watches Experts
Ngoro
john h
Are you an Invicta Watch Expert? Answer questions, earn points and help others
