f
fisha Posted on Sep 02, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How can i reboot it it shows me error code ce40
Steve Butterworth
Level 3:
  • Master 938 Answers
  • Posted on Sep 02, 2015
Steve Butterworth
Master
Level 3:
Answers
938
Questions
Helped
240968
Points
3298
Search online for "error code ce40 + your make & model"
I have an error code CD 40 on a Toshiba estudio 2540. Do you know what this code means. Thank in advance. Joe
Do u mean CE40? Because there is no CD40 error code...
CE40 is image control related service call where the image quality control test pattern abnormal.
Image quality control abnormal detection display/0 clearing
08-2528 Y
08-2529 M
08-2530 C
08-2531 K
From above u know which process unit giving problem, then further check the main charger, developer...
Ce40 error on toshiba 3040c - Toshiba e-Studio 3040c
CE40 is image related error, u need to check which pu giving the problem...
2answers
Error code ce40 on toshiba e-studio 2040c copier machian
Perform 08-2002 "0" to clear the error
If problem persist, clean/replace the themopiles
CAN YOU PLEASE GIVEN THE SOLUTION FOR ERROR IN ce40 code in estudio2050c
You must change black dev.unit lever clutch to fix CEB0
And you must change the belt that moves organic belt to fix CE40.
CE40 is image related problem, u need to check which PU is giving the problem
4helpful
Toshiba estudio 2830c error code ce40
I want to locate the position of the image sensor for a toshiba E-Studio2500c.
1helpful
BOTA ERROR CE40
[CE40] Image quality control test pattern abnormality
1.Replace the image quality sensor
2.Set the values of "Image quality closed-loop control / Contrast voltage (08-556)" and "Image
quality closed-loop control / Laser power (08-557)" to "1" (Valid). MEANING Shutdown the machine,press 0+8,while starting the machine, enter 556 then enter 1,confirm it,then press 557 then 1,confirm it.
Below are further instructions in the same way
3.Perform "Enforced performing of image quality open-loop control (05-394)" and make sure it is
completed normally. (Error [CE40] does not appear.)
4.Clear all "Image quality control abnormal detection counter Y to K display/0 clearing (08-573 to
576)"
That is it
k24674
ADMIN Andrew
ADMIN Andrew
