My Samsung TV model LN-4665F will not turn on. Is there a reset button i'm not seeing, or perhaps an internal circuit breaker or fuse?
The tv would not turn on from either the remote or onboard switch. I do not see an external reset button. I unplugged it form the AC for 5 minutes. No luck. Then for 2 hours. No luck. Before i take it apart, I need to know if there is an internal fuse or circuit break to reset, or does this just need to go to the shop instead of my trying to fix it?
? 13:13
https://www.youtube.com/watch?v=SXqSg2A5b7I
Jan 6, 2012 - Uploaded by Tampatec
Must See TV FIX EASY COMMON Samsung TV Repair Repairing LNT LCD PLASMA TV ... video tutorial television flat-screen model # kdl ln lt lnt hp ht LINK for TV boards & Parts ... 1. soft reset - is just turning tv off & back on ..... the source by using the on/off button on the side panel, remote does not work.
check make sure you have power
check the power strip is working
check electrical and power cords
unplug the tv from the wall and remove the plug from the tv
inspect the wire or plug connectors and plug areas
check the batteries for the remote, if not sure replace them all
go to fuse panel reset breaker, trip and reset breaker
than reconnect everything and try turning tv on
see if you can find reset button, push to reset
find out if the tv has a fuse, check the fuse
after all that a new tv/ see if it worth repairing most of the time it cheaper to buy new one or a referbushed unit.
Your TV has a fuse on power circuit board ( that is a standard part).You need to resemble your tv to get the fuse ( make sure to disconnect all power and antenna before doing this service). Usually any tvs use a clear glass cover on fuse ( you can see a small conductor inside the glass). Replace the fuse if the small conductor gets broken. If after the fuse replacement, you got no joy on tv, the receiver part could be get problem also ( due to storm attack) and need to repair / replacement.
Try a hard restart, which simply means unplugging the power cord of the
TV, and replugging it after 4 hours have passed. This technique
reprograms the electronics, to a certain extent.
The only possible check that could be done without removing/opening the Audiovox TV would be to check for the presence/absence of supply power/voltage depending on how the TV is powered (12VDC or 120 VAC). Normally, there would be an fuse and/or circuit breakers.for the RV's entertainment system including the TV.
The 120-volt circuit breakers and 12-volt
fuses are located in the same compartment. These devices interrupt the power if
the circuit is overloaded.The 120-volt circuit breakers include a 30
amp main breaker and several smaller breakers for individual circuits. If a
circuit breaker is tripped, look for an overload on the circuit, then reset it
by turning the breaker OFF and then turning it ON. Do not try to reset a breaker
the second time without locating the overload problem. The 12-volt fuses protect
individual circuits. If the circuit is overloaded, it will blow the fuse and the
fuse must be replaced. Check the circuit for an overload and replace the fuse
with the same type or amperage rating.
If the above checks out, then problem is internal to the unit and would require removal from its current position.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
