Error codes on Oce plotters, including the Oce Plotter 340, can indicate various issues. Unfortunately, I don't have specific information about error code "22552" for the Oce Plotter 340, as error codes can be specific to the manufacturer and model.
To troubleshoot the issue, you may want to consult the user manual or technical documentation for your Oce Plotter 340. The manual should provide information on error codes and possible solutions. If you don't have a physical copy of the manual, you might be able to find it on the manufacturer's website or by contacting their customer support.
In general, error codes on plotters can be caused by issues such as paper jams, communication problems, hardware malfunctions, or software errors. If the issue persists and you cannot find a solution in the documentation, it may be advisable to contact Oce's customer support or seek assistance from a professional technician who specializes in Oce plotters. They may be able to diagnose and resolve the specific problem you're facing.check;
Try to verify this by sending the same fax to other fax machines. If these transmissions are successful, then notify the user of the remote machine to make them aware of the issue.
If the fax fails when sending to other machines, turn it off for 10 seconds, turn back on, and then try sending again.
Error Code: 334 Definition
The remote fax machine might be defective.
Solutions
communication error 43 is error of telephone line.there is some distarstion in telephone line.some noise in line .due to this it is facing problem.just clear ur line .or check with an other line.by mian jee
03-321, 322, 326, 327
LLM to ISIL communications problems
03-328
IOT communications problem with duplex or tray 4
03-330
IOT communications problems with HCF
03-335, 03-336
LLM communications problems with edit
03-340
NVM memory
03-341, 03-347
Communications problems between IOT and sorter
03-350, 03-354
Communications problem with LLM and user interface
03-363, 03-364
Communications problem between LLM & optics
03-370, 03-372
Communications problem between LLM & DADF
03-380, 384
03-416, 03-422
RAM memory problem
03-424, 426
NVM memory problem
03-430, 432
Billing problem
03-439
GRAIB communications problem
03-440
RIC communications problem
03-441
RIC NVM problem
03-442
Modem
03-443, 03-458
RIC problems
