Dometic New 13500 BTU Duo Therm Brisk RV AC Complete Scratch and Dent Logo
T
Tim Pierce Posted on Aug 15, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Fan runs but does not cool
Unit is new last year and has only been run less than 5 times
  • Kelly C
    Kelly C Aug 26, 2017
    I'm NOT AN EXPERT I DO MY OWN HOME REPAIRS AS A SINGLE MPM I HAVE TO. I WOULD first check for a loose or kinked wire to the capacitor. then I'd check the capacitor with a multimeter. It may be freezing up like mine did so I'd switch it to the front a\c until it thawed, (if you have one) Just saying because mine was a motorhome, then I kept it at a lower temperature to prevent the freeze. You may also have a hole in the line somewhere. letting the freeon(gas) out.
  • Kelly C
    but make sure the capacitor is discharged before testing it.
john h
Level 3:
Top Expert:
  • Dometic Master 29,494 Answers
  • Posted on Aug 26, 2017
john h
Dometic Master
Level 3:
Top Expert:
Answers
29494
Questions
0
Helped
7547064
Points
193449
Is compressor running --frozen coil --dirty coil -- thermostat failure compressor failure low or no freon etc the list can go on need to have diagnosed and or system tested
Kelly C
Level 1:
New Friend:
Problem Solver:
  • Contributor 8 Answers
Kelly C
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
8
Questions
0
Helped
2960
Points
30
Always take pictures first before you fix
anything, or take it apart. so you will know how to put things back
5 Related Answers
Anonymous
  • 828 Answers
  • Posted on Jun 28, 2008
SOURCE: duo-therm quick cool
Your compressor is trying to restart after it shuts off which is causing a power draw down changing the sound of the fan speed change. Check voltage power supply and insure that the power supply cord is heavy enough to carry the necessary load.
motor1258
Mike Butler
  • 6674 Answers
  • Posted on Aug 14, 2008
SOURCE: Air conditioner fan will not come on and unit will run for 1 minute and stop
You hear the compressor kick in (Hum) but no fan comes on? Will the fan come on when just in fan mode, not cool, or do you have that set-up?
Bill Long
  • 606 Answers
  • Posted on Jun 09, 2009
SOURCE: RV air conditioner. Compressor running, fan stops before cool
The fan motor is getting hot and going off on the internal overload in the motor.
This is caused by either a low voltage, a bad capacitor, or tight or dry bearings in the motor.
To check the bearings turn the power off to the unit, then spin the fan blade if it spins freely then the bearings are ok.
To check the capacitor you will need some kind of tester or you can buy a capacitor and replace it, that's what a lot of people do. They usually don't cost very much.
To check the voltage you will need a voltmeter and measure the volts at the unit.
Anonymous
  • 12 Answers
  • Posted on Aug 20, 2009
SOURCE: Fan Runs, AC Doesnt, Blinks 5 times
Need to look around and should have an error code and give more detail of what the problem is. If you post that i can maybe help you more. I need to know......
Anonymous
  • 15 Answers
  • Posted on Jan 29, 2010
SOURCE: Carrier A/C in RV won't run
check your breakers make sure when running unit this is the only thing on the breaker 15 to 20 amp be sure to keep a window cracked as well unit does freeze over so don't have all the way on cold
1helpful
2016,Kia Sedona V6 temp code check engine light ?
Look for a broken wire or an incorrect voltage to the sender sensor wire.
1helpful
I had Ruud heating and cooling installed five years ago. Last summer my electric bill doubled when I began running my air conditioner. It did not do that the first few years that we were in this house. ...
Hello In a way you are stuck with what is called a S.E.E.R. rating which is a statement of efficiency from the manufacturer.Ex: a 10seer is less electricity to run than a 14 seer.The model # would have told me the seer rating.A 4 ton `1 zone is a large unit but even a 10 seer 4 ton is never cost prohibitive to operate and Never doubles the electric bill in 5 days out of thirty.Is the home unoccupied all month and you use it on weekends?Did the neighbor run a strange wire to your property?There might be stray or lost voltage in rare cases if there is poor grounding issues.Has the unit been serviced? A low freon charge will cause a unit to run excessively long and not cool.Do you run the indoor blower all the time.Has there been any other major purchases made (at all) that you plug in?I would look at everything because there is some cause for DOUBLE bill amount not just the cooling bill.Good luck
1helpful
3answers
Cooling fans run all the time
Some temperature sensor is faulty!
1helpful
Amana Cooling Condensing Unit fan won't kick on
be aware that not repairing this asap that you are causing yourself more problems First I would change out the fan capacitor and see if this could be the problem. Secondly if the capacitor isn,t the problem change out the motor . By continuing to allow the system to cycle like this the compressor will take a dive on you costing more . Good Luck
Dave
1helpful
2answers
Side by side (KSRB25FHSS05) loosing cool in freezer
your compresor is hot but is it running at all or is it just humming trying to start and the just clicks off if it is just your overload that is tripp you need to replaced it that the box connected to the compressor on the left side that is why not is cooling if is running then is cheaper to buy a new one since the 5 year warranty on the compressor has expired
Ruud heat pump outside fan
You may be right in looking at the motor. It uses a different speed on heat than cool. The heat cycle uses low speed, usually red. Some manufactures use blue (medium). Cool uses black, high speed. If you are confident, switch the low speed wire with the high speed and see if this changes anything. If the fan motor isn't the problem, check the other setting (cool) if the overload trips, you may need to look into a new capacitor or compressor, if so, you can install a hard start kit. these are start boosters, and are inexpensice, sometimes they will give another year out of the comp. but I've put them on and they have lasted 5 years.
Top Dometic Renewable Energy Experts
Florinda Byers
Level 1 Expert
RAJA NADEEM AKHTER
RAJA NADEEM AKHTER
Are you a Dometic Renewable Energy Expert? Answer questions, earn points and help others
