SOURCE: PLTV-26
WHEN I TURN ON MY TV THE LED IS RED THEN GREEN AND GOES BACK TO RED AND NO IMAGE. WHAT COULD IT BE, i ALSO DID A HARD RESET BY REMOVING THE WIRES AS THE TECH HAD SAID AND NOTHING.
SOURCE: stuck on amber light will not turn on
An amber light normally means that there is no signal getting to the screen, if it was stuck in standby then the LED would be red.
Please check your connections to cure the fault
SOURCE: power up not likely
This could be anything, literally. My first guess would have been the power supply but you have eliminated that. The rest of the unit is really not serviceable by home owners and would be very difficult for someone without any training. About the only other checks you could make is to check all the fuses. All boards should have at least one and may have several, including some microfuses which are typically marked as Fxxx (where x is a number). Additionally look for charred components (resistors in particular) or burn marks on the board. Check for loose plugs in sockets on interconnection wiring. If everything checks OK you need a repair tech. Furthur troubleshooting can only be done by a competent repairman. It does not sound like the problem should cost all that much to repair in relation to the cost of the TV. Good luck.
SOURCE: ON MY LCD TV I
If tv screen is just black then it sounds back light inverter board problem that is not producing light in lcd panel to show its image.
Check at rear of tv for bright white light coming from any vent holes, if no light found then back light is not working.
Point flash light on tv screen and try to observe faint image in screen that is another evidence that back light is not working.
Local tv repair shop will help you replace back light inverter board to fix tv problem.
Let me know if you have additional question.
Thanks.
I have the same problem c an I get help
