ALL LIVING THINGS Neodymium Basking Bulb Logo
M
Mikaela Vellucci Posted on Aug 08, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can I be sent a replacement bulb?
I got mt bulb only 2 weeks ago and it has already burnt out.
Mister Danger
Level 3:
  • Master 5,631 Answers
  • Posted on Aug 08, 2015
Mister Danger
Master
Level 3:
Answers
5631
Questions
0
Helped
1199184
Points
47629
Mikaela Vellucci:
For a start, I feel you are somewhat confused. Fixya is a Q/A forum. and those who answer your questions, we are Fixya users like you. So, we don't provide anything and of course we can't send you those bulb.
Saud this, we can help you in your research. Try calling this people:
http://www.lllreptile.com/info/library/care-and-husbandry-articles/-/review-of-reptile-heat-bulbs
See toolfree phone numer on website
also you can visite the following wesites and contac them:
All Living Things Reptile Neodymium Basking Bulb Bulbs Lamps PetSmart
Shop for Reptile UVA UVB Bulbs
Crickets Fluker Crickets Farm Inc
http://www.herpsupplies.com/subcategory.cfm?id=11&sub=32
1helpful
Iorder a iphone nano 2 weeks ago and i never resiv it
Usually, you can see if the seller has already shipped the item, and if there is a tracking number associated with the purchase.
If you have already paid for the item (2 weeks ago), and the seller hasn't shipped it (... as shown in the item status info), send an inquiry eBay message to the seller (using the Action drop-down menu - contact seller) .... to find out if & when it has been sent.
If it is an international sale/shipment, it may take longer to get it, as indicated in the shipping time estimates provided (with the item info).
Yes, some sellers don't send their items out too quickly.
And if you don't hear from the seller or still hasn't received it in 3 weeks, you'll want to open a case ... to get eBay to intervene on your behalf . The case must be open within 4 weeks of purchase.
I HAVE A SONY PLAYSTATION 2. WE HAD A POWER SURGE 1 1/2 WEEKS AGO. THE LIGHTS WERE OUT FOR 7 HRS. I WAS PLAYING WITH THE PLAYSTATION WHEN IT HAPPENED. WHEN I PUT IN A MOVIE OR DVD, THE SCREEN IS BLACK. IS...
This playstation can already have a burn main board because of what happen, and I believe your insurance needs a written information from the manufacturer which is Sony before they replace it, unfortunately we're not connected with Sony this is Fixya...So better contact Sony so you can have it replace from your insurance...
Hope that helps...
Saturn sc1 3 bulbs burnt out at one time after I just replaced both headlight bulb
Hi Legalass, Condensation will be caused by water or moisture entering the head light unit. If the lens is cracked or broken or the cover are not correctly fitted that will answer that part of the question. I think for the second part of the question you should take the vehicle and have the voltage regulator output checked. It is possible that the alternator is being allowed to over charge and when it does, it may be blowing the bulbs! Regards John
I had a lowbeam headlight on my G6 replaced 2 weeks ago with a anti humidity headlighit and it has already gone out again. Was the bulb defective or what? I bought the bulbs at the auto parts store. Do...
Is there a breach in the headlight assembly? Is the bulb fouled (blackened) or cracked? Do you have the correct bulb type? Is it a cheapo bulb? Local vibration can cause premature failure (make sure bulb and assembly do not wiggle
I have a 94 ford probe, The radio works when it wants to.. but the prblem is the tail lights and dash lights went out about a week ago, Checked all fuses in car and under hood checked all light bulbs all...
You need to replace headlight switch - if fuses, bulbs, wiring looks good. Avoid the toggle switch idea, you'll be opening a whole new can of worms.
1helpful
2answers
We purchased a reebok edge 2.2 treadmill about 3 weeks ago, a couple of nights ago the electic trip out whilst using the treadmill and since then the belt hasn't moved the display still works and counts...
i had the same problem, i beleive its the motor it may have burnt out.
only had it less than 4 weeks, argos sent a replacement treadmill and took the broken one away.
1helpful
2answers
No odometer light, circuit?
I own a 2000 impala ls and encountered the same problem.My solution to my problem was buy a new light switch and it worked.The circuits on the old one seemed to be burned so thats why they would come on sometimes.To install the new switch you need to remove the faceplate on the dash board and behind it you will find two screws holding it in place remove the screws and unplug the switch and replace.
2answers
Light behind "Fan Speed" Dial burnt out?
It can be replaced with just bulbs. They are a pain in the **** to get ordered correctly but the are serviceable. Also, you can change the shifter light bulbs as well, just turn the bulb 30 degrees or so and pull out gently.
4helpful
3answers
Display light burnt out
Solution #2 is incorrect. Alpine service charges a flat $95 for repairing a CDA-7998. How do I know? I sent mine in two weeks ago and got it back a few days ago. They
1) Replaced the burned-out biolite display
2) Replaced the fantomface cam gear
3) Replaced the main logic board
4) Cleaned the laser/pickup optical assembly
Charge: $95 including return shipping.
Dim strip across the top 2" of my wega
could be the lens in front of your lamp is dirty. When I had a burnt out lamp and replace it with a new one, they sent me the wrong housing for the lamp, so I took apart the housing and removed the lamp and swap it out with the burnt out lamp.
While I was doing all of this I notice the area was very dirty from dust. The lens is square in shape and looks kind of like a Fly's eye but is a clear glass lens. Except my was not clear. It was very dirty.
Or something could of falling in it's optical path, like a wire just dangleing.
Good luck
Bobby G AKA poolmvp1
Top ALL LIVING THINGS Reptile Experts
john h
Don A
Don A
Are you an ALL LIVING THINGS Reptile Expert? Answer questions, earn points and help others
