I have an LG50ln5600UI television with a backlight out. used the flashlight test and can see the pic behind. researched and found no backlight inverters. intead i replaced the powersupply/led board. same issue, no change. when i turn on, the LG logo appears for split second. then goes blank. can see pic in background with flashlight. when turning off, i can see a backlight flash at the lower ege of the screen. Ideas?? service code is 50ln5600-ulbusylhr.
Check whether the back-light start voltage [control voltage] comes to the backlight inverter section of the power board; from the main board. It sounds that that voltage does not come from the main board, after the firmware has been loaded up. If so the main board will have the fault. Contact any service technician.
