Danby DWC283BLS Wine Cooler Logo
j
julie swing Posted on Jul 25, 2015
Model dwc283bls top fan motor not working
Top fan motor not working.fan output reading is 12 volts.
1 Related Answer
Anonymous
  • 713 Answers
  • Posted on May 06, 2010
SOURCE: Describe your danby dwc283bls top
Hi,from your problem,it seems the problem is from the logic board,you can however use a mulimeter to read the voltage supplied by the board,if it reads a low amount of voltage it means the board need to be serviced and cleaned thoroughly,but if it reads no voltage at all meaning its not supplying no amount of power,it means the logical board is bad and needs to be replaced.
Thanks and take care
Blower not working
Tell us what make an model of vehicle you are using in your description of the problem. Blower not working can be caused by:
1. Blown fuse
2. Bad fan switch
3. Bad resistor speed selector unit (changes voltage going to fan motor.
4. Melted or bad connector, usually between switch and motor.
5. You have lost the ground from the fan going back to the battery. ie, a bad connection.
You will need a volt/ohm meter after you check the fuse.
Make sure you have battery voltage (about 12 volts) coming to the fan switch. If you do get 12 volts, follow it in the circuit going to the blower fan until you stop getting 12 volts. Where it stops is where the problem is. You can also start the test right at the blower fan with a meter to see if the fan is getting 12 volts and work backwards towards the switch.
Most likely cause: Bad resistor pack or connectors melted going to it, followed by a bad fan switch.
99 chryler sebring 2.0 radiator fan not working
1 check fuse and or make sure you have 12 volts at fan conection
2 the fan has a thermostat to tell it when to come on when water temp gets
to about 160 or so, check for 12 volts at fan connector when motor is warmed up if no 12 volts replace thermo stat
3 check fan motor whith an ohm meter, if the reading is zero then the motor is bad and ned to replace the entire fan unit. cheep at junk yards
1helpful
Fan on my big buddy heater just stopped working changed batteries still not working?tried the switch nothing .i only have radiant heat.
I would first check the wiring connections to fan and get a multi meter , set on 12 volts dc and see if fan motor has 12 vdc input voltage.
Too cheap to buy a voltage tester at wal mart ot harbor frieght, you can use a 12 volt bulb and socket, if you already have one. Remove fan wires & hook up 12 volt light bulb & if it lights, you got the juice. Carefull,dont let live wires touch because you short out $26.00 big buddy fan transformer. work with fan transformer unplugged from wall and dont plug in until you sure no wires touch.
use electrical or duct tape. electrical tape better.
otherwise,just buy the multi meter, they only $8.00 to $10.00
read & understand instructions, before you try to use it. otherwise,you could burn out your new meter.
well worth owning &
learning to use multi meter. I use it thousands of times.
if fan motor has juice but wont run, check fan shaft to see if it turns freely or scrapes or is stuck. oil fan motor bearings ,change the brushes.
make sure that the fan blades are not touching the fan housing and can turn freely.
if it still dont work, buy new fan motor.
if no juice at fan motor, check mr heater switch with the power off,unplug transformer from the wall or remove batteries.,
and use the ohm meter setting of the multi- meter to test for continuity of the switch when the switch is in the on position.
power must be off when using the ohm setting of a multimeter.
if power is on & using the ohm setting of the multi meter, you will blow out the multimeter. The ohm setting uses a 1.5 volt dc battery inside the multimeter to test for a compleated circuit.
so, 12volts dc would blow it out on ohms setting.
TESTING FOR OUTPUT OF FAN TRANSFORMER OR BATERY PACK.
If the switch is good,reinstall it on mr.heater and test the output of the transformer or battery compartment using the 20 volt dc scale of the multi meter. the voltage scale you select ,must be higher than the voltage you expect to find ,in order to avoid damage to the multi meter.
observe polarity,positive to red and negative to black.
the dc voltmeter setting is totally polarity sensitive and a reversed hook up could blow out the meter.
multi meter means it can read ac volts, dc volts,ohms and dc amps. Read and understand the included instructions before using a multi meter
a good single battery in new condition reads 1.62volts dc
1.5 vdc is almost dead, a good used battery reads 1.58 to 1.6 vdc
below 1.58 vdc is weak battery and 1.48 vdc is usually totally dead, but may be enough for momentary usage under 1 minute.
1helpful
Evaporator fan not working!!
The fan on this model is only 12 volts. Make sure that is what your replacement is rated.
The cooling fan on my 1993 Mitsubishi Diamante is not working but I do know the fan motors are OK, How do I check the sending units and relays?
the sending unit will give an output reading of 12 volts to the relay. If the voltage is currently going to the relay replace the relay
Describe your danby dwc283bls top fan does not work. after removing the fan ,the problem is no output from the logic board, defective board or another part,sensor etc.????
Compressor runs and gets hot but does not cool unit
This product has been discontinued
i dont think many danby units are parts supported
more likely generic after market parts fitted by air con mechanics do the job
relay first might be a thematic one and an compressor motor fan relay
then check gas pressure
https://www.winecoolerdirect.com/danby-wine-cooler-dual-zone-dwc283bls/DWC283BLS.html
Service Manual.pdfwww.reliablepartsinc.com/danby/Manuals%20.../Service%20Manuals/DWC282%20%...
2answers
Top Danby Furniture Experts
ZJ Limited
ZJ Limited
Are you a Danby Furniture Expert? Answer questions, earn points and help others
