An "E06" error code on a Maxx Optix 7242 Model typically indicates that there is a problem with the water sensor. To resolve this issue, you will need to replace the faulty water sensor. Here are a few steps you can follow to obtain and install the replacement part:
Contact the manufacturer or a reputable appliance repair company to obtain a replacement water sensor for your Maxx Optix 7242 Model. You may be able to find the part online or through a local appliance parts store as well.
Follow the manufacturer's instructions for installing the replacement water sensor. This may involve disassembling the dishwasher and accessing the sensor. If you are not comfortable performing this task, it is recommended to contact a professional for assistance.
Once the replacement water sensor is installed, run a test cycle to make sure that the error code does not reappear.
If you continue to experience issues with your Maxx Optix 7242 Model after replacing the water sensor, it is recommended to contact a professional for further assistance in diagnosing and repairing the issue.
If there is an f57 error code, in 80% of cases the problem is related to the motor control board. But do not rush to buy a new one for your Bosch washing machine. When you solder the components of the board, they may be damaged as a result of the strong vibrations of the machine. Therefore, you need to monitor the correct and stable installation of your washer. In many cases, an experienced master can bring the device back to life. It will significantly save your budget. Think before you start an independent repair. Remember that the new electronic unit is quite expensive.
error E:00 in Bosch
Caroline, Could not find anything pertaining to this Bosch code. You may be can contact Bosch at last link posted or download manual.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
