There seems to be no coax cable input on my MAG M572TVs - 15" LCD TV. I don't see a connection anywhere. This LCD TV monitor has mass connections which is nice but there is no coax connection. The manual says there is supposed to be but does not show you where, it simply says plug your monitor into you TV using a coax cable and then scan for channels. Please help!
here are the only signal inputs located at the back of the tv. 1 x HDMI input ( 19 pin HDMI Type A )
2 x component video input ( RCA phono x 3 )
1 x VGA input ( 15 pin HD D-Sub (HD-15) )
Audio line-in ( RCA phono x 2 )
2 x S-Video input ( 4 pin mini-DIN )
2 x composite video/audio input ( RCA phono x 3 )
1 x headphones ( mini-phone stereo 3.5 mm )
1 x SPDIF output ( TOS Link )
1 x audio line-out ( RCA phono x 2 )
1 x subwoofer output ( RCA phono )
1 x serial
If you are looking for a coaxial cable input.. it is actually not available so you have to connect a converter from coax cable to RCA cable for you to connect it on your tv.
Lets start at connections. What is your cable source? Do you have a converter or cable box connected to your TV?
YES : You must have two connections, so you will need to run a second coax cable from the wall. This can be a $10 fix and a 15 min hook up. (Ask if needed). You will also have to be using your TV through caox inputs (TV Source on TV)
NO: You will need a second line ran and hooked up to your TV input. (Ask If need specific hookup on model)
If the TV part works normal then you are probably trying to use a resolution and or refresh rate the monitor cannot handle. You want to be on 1024x768 max and 60hz refresh. You can try starting the computer in safe mode to test.
1. Check the cable connection to your PC. It might be disconnected.
2. If your have more then one cable input on your LCD monitor(VGA or DVI) check if you selected correct input; digital for DVI or analog for VGA.
through the Remote .. press menu .. and make sure that the VGA output is one that the Monitor can handle (if LCD 1280x1024) ... lower the refrech rate or definition until the monitor 'sinc's
