Question about Konica Minolta Bizhub C552 Copier
Konica Minolta C552 error code C-B02
Showing erroe C-3B02 when the machine is on
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
WHERE IS THE IH POWER SUPPLY LOCATED
Posted on Sep 23, 2015
    New Friend:
  • 11 Answers
Replace the IH Power supply, it will solve your problem... Page 71 Item 5 from the parts manual.
Posted on Jul 17, 2015
SOURCE:
Konica Minolta C552 wrong image unit caused C-CD10 Error, changed boards, disconnected hard drive, reformatted hard drive, updated firmware. Took out fuser still gets code. Hytec doesn't know.
The Hard Drive is not formatted. First, get in service mode, State confirm, HDD ADJ, HDD Format. Run Physical first, about two hours then logical a few minutes . Does the machine know it has one, Installed/Uninstalled in service mode. Then replace.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Mar 02, 2017 | Konica Minolta Office Equipment & Supplies
Machine has error code c-3b02
Check the fuser unit the HOT Part. ensure properly installed. could be the fuser control board or the fuser High Current coil that part the fuser sits up against.
Jan 18, 2016 | Konica Minolta Bizhub C652 Color Copier...
ERROR CODE C3B02 KONICA MINOLTA C552
Have you changed the fusing unit? If try that first, then relace the IH Power supply or the (coil unit) is what the fuser attaches to when you install one. power supply is located right side under the control panel, .
Sep 23, 2015 | Konica Minolta Bizhub C552 Copier
I have konica minolta c552 has an error C3b02
Hey jrf, the manual says to check, in this order; proper fuser installation, proper closure ( door latch ) of the right hand door, check around-all around-for wiring connection issues, change fuser, then coil, then IHPU, then PRCB, then REDB. If you have a trade-in, or lease return, at the shop; it might pay to do some parts borrowing.
What is bizhub C552 p-14 error?
p codes are warnings that a consumable is reaching the end of its life you can go into service mode and it will give you a list of error codes including p codes
Jul 04, 2014 | Konica Minolta bizhub C552 Waste Toner Box...
C163 on b52izhub c5
3B02,3B03,3B04 - IH malfunction.Try reset the error code:
Turn OFF the copier,press and keep pressing the Function key and turn ON the copier.Keep pressed the Function key until appaire the Trouble reset message on the display.Release the Function key ,touch the message and turn OFF the copier.Wait 1 minutes and turn ON.
Dec 23, 2013 | Konica Minolta Bizhub C452 Copier
Konica Bizhub C452 Error C-3B02
chek your register conector
open the front door and clean conector
May 26, 2012 | Konica Minolta Bizhub C452 Copier
What does Error Code C2564 Konica Minolta Bizhub 552 mean
Black drum ATDC replace the black developer unit, also check to make sure the black toner is getting into the black developer unit. Open close the front door to reset the code (Not the Toner door)
Apr 24, 2012 | Konica Minolta Bizhub C552 Copier
How do I clear error message C-2558 for the Konica Minolta bizhub C253
tis error means abnormal tonder density in the balck image unit take the blacke image unit out and shake it while holding it level and put it back in the machine to reset the error code leave the machine on and open then close the front door
Nov 12, 2009 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta Bizhub C552 Copier Logo
297 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
