Konica Minolta Bizhub C451 Printer/scanner/finisher Logo
Abiodun Agunsoye Posted on Jun 29, 2015
On startup, it stops at the Konica Minolta display and does not go further to the home screen
abumoiz
Level 1:
New Friend:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Contributor 18 Answers
  • Posted on Jun 30, 2015
abumoiz
Contributor
Level 1:
New Friend:
Night Owl:
Answers
18
Questions
Helped
33606
Points
59
The problum is in the sencer in bottom which is durty
Testimonial: "Thanks abumoiz but pls can you help me with the location of the sensor (I guess)"
  • Dirham Dhani
    Dirham Dhani Mar 05, 2020
    which one the sensor
Solomon Nyah Mator
Level 1:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 1 Answer
  • Posted on Mar 26, 2019
Solomon Nyah Mator
Contributor
Level 1:
New Friend:
Welcome Back:
Answers
Questions
0
Helped
8783
Points
So what can be done pls help
Martin Haba
Level 1:
Habit-Forming:
New Friend:
  • Contributor 36 Answers
  • Posted on Sep 30, 2016
Martin Haba
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
36
Questions
0
Helped
20875
Points
70
Replace Memory modules to start with. If that does't help, then your MFPB might be at fault.
You can try Trouble Reset the machine or updating firmware.
The procedure to trouble reset is to Power down machine completely and press and hold Utility/Counter button > Power up machine whilst holding down Utility/Counter button and wait for black spot in top right hand corner. When it appears release Utility/Counter button and wait for white screen with Trouble Reset button in the middle of the display. Tap on it, it should point with arrow down saying OK. Now Switch off machine completely for 10 seconds. Now power up machine again and see if it came back to life.
Konica bizhub 423 red light blinking
If the red light is blinking on your Konica Bizhub 423, it usually indicates an error or issue with the printer. Here are a few things you can try to resolve the issue:
  1. Check the display panel: The display panel on the printer should show an error message or code indicating what the issue is. Check the manual or contact Konica Minolta support to find out what the error code means.
  2. Restart the printer: Try turning off the printer, unplugging it from the power source, waiting for a minute or so, and then plugging it back in and turning it on.
  3. Check the toner: If the toner is low or empty, the printer may not function properly. Check the toner levels and replace the toner cartridge if necessary.
  4. Check for paper jams: Paper jams can cause the printer to stop working. Check the printer for any stuck paper and remove it carefully.
If none of the above steps work, you may need to contact Konica Minolta support for further assistance.
How to clear on shown display in konica minolta maintenance call m2 call service
Konica minolta bizhub 215 showing maintenance call(m2) and service callProcedure1. Press the COUNTER. (UTILITY)2. Press the following keys in this order:STOP 0 0 STOP 0 13. Enter the code number corresponding to the function to be used from theKEYPAD.4. Press the START.< Exiting the Mode>
• Press the AUTO RESET until the initial screen reappears.
Utility-stop-0-0-stop-0-1 for service mode. choose clear data, then supply countthen ok to clear. On/ Off the machine it will work as usual.
We have two Konica Minolta (Develop) c203s which won't boot up. Both working fine one day, then overnight seems to have frozen. I.e. Turn of the main power switch, the two status lights (Orange and blue)...
Try to Troubleshoot By SWITCH ON MACHINE FROM MAIN POWER SWITCH BY PRESSING UTILITY BUTTON.
-WAIT AND KEEP HOLDING UTILITY BUTTON
-AFTER 10 TO 15 SECOND, TROUBLERESET OPTION WILL APPEAR ON SCREEN, TOUCH IT AND SWITCH OFF.
-NOW ON NORMAL WAYS.
if not ok, then check the panel connection.
- after switching off and on, wait and observe if it display KONICA MINOLTA SCREEN OR Hour Glass symbol.
and let me know for further diagnostic.
My konica minolta c353 the screen is not displaying
See if you can get a new control panel.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
C-6102 error is displaying how can i fix in minolta 224e
look the scanner home sensor or try this turn off the printer and keep pressing stop button and turn on
Dialta di2510 not initializing
Unplug it from the wall, wait a while and plug it back in. If still not booting, Probably needs to have the firmware reloaded,or all the dimms (memory chips) need to be reseated, or the main board has failed. If you are not a tech, probably should call one.
I want to change my konica sitios 7020 printer to english,its in japanese
Procedure
Touch 1. System Initial on the Key Operator Mode Screen to display the System
Initial Setting Menu Screen.
2 Touch 2. Language to display the Language Selection Screen.
3 Touch ENGLISH, FRENCH, SPANISH, GERMAN, or ITALIAN
Touch OK to complete the setting and return to the System Initial Setting Menu
Screen.
5 Touch RETURN to restore the Key Operator Mode Screen.
6 If no further changes are required, touch RETURN to restore the Basic Screen to
perform copying operations
2helpful
Hi. I have a Konica Magicolor 3300, and it always prints a Startup Page each time I turn it on. Could you let me know how to disable Startup Page in Konica Magicolor 3300? Thanks.
It is under the Administrator Menu:
From an Idle state, Press:
Menu
Next - you should see "configuration administration" on the display.
Press the left or right arrow key until "Administration Startup Options" is displayed.
Press "select"
Press the left or right arrow key until "do start page" is displayed.
Press select.
Press the left or right arrow until "no" is displayed.
Press "online" (save changes *no? should be displayed)
Press "next" (right arrow) "save changes? yes" should be displayed.
Press "select" to save settings.
Press the select to reboot the system.
This came directly from the operators manual, and may differ depending on the firmware version of your machine. If this does not work, please let me know and I will research it further.
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
