What molly bolts are you talking about. A
molly or
molly bolt, often misspelled
moly,
[1] is a formerly trademarked
[2] name for a specialized screw
fastener used with
drywall, as a
hollow-wall anchor. Larger sizes permit reasonably heavy objects, such as shelving,
flat screen-TV mounts or central-heating radiators to be attached to drywall in locations where there is no
stud behind the drywall. For heavy objects, multiple molly bolts may be required.
. You can use adhesive to glue to walls. The unit must be level and square. The corners in your home are not 90 degrees but close.Please don't drill any holes in unit., unless directed to.Holes in-walls are hard to seal. Let me know what unit number your shower is and I will help you.
