SOURCE: ECM - Eror Correction Mode Brother IntelliFAX 770 Plain Paper
Not sure why you would need to turn it off according to manf. it only work with another fax machine that has the same ECM installed and only if there was a problem with the fax that was sent or recieved
SOURCE: Brother Intellifax 770 fax machine failure to receive faxes
I HAVE A BROTJERS 770 AMD ALL I DONE WAS GET A 2 SPACE TELE JACK AND PLUG IT INTO MY MODEM FROM COMCAST AND PLUG MY PHONE AND FAX INTO IT AND CAN RECEIVE AND SEND
SOURCE: Brother Fax Machine 4100 - check or remove original message
Sounds like something is going on with your ADF. It should be looked at by a technician.
SOURCE: check paper reload paper
Remove the paper tray completely and make sure paper is not binding and lifting up OK.
I get calls all the time about fax issues. I work for Comcast and have guided people to the right answers about third party devices. We use a digital connection. Analog is a dying medium. Most calls are concerning HP and Brother but I know others fax machines have had problems too. The new HP machines have a digital setting. HP is aware of digital issues and can help you. It is unfortunate that old fax machines are not digital but a new fax is inexpensive if you wish to buy one. Analog takes up too much space. An example: Six digital television channels can fit in the same space (bandwidth) as one analog. That is why the FCC mandated the change. The same goes for phone lines. I Google almost every problem concerning fax machines and if you go past all the upset comments you will get to the comments that offer remedy. I also wanted everyone to know that a second, no frills fax line from Comcast is very inexpensive and our way of offering a dedicated fax line intead of a distinctive ring fax option.
