SOURCE: TI-84 Plus Calculator will not turn on, says ram is cleared
Thats because the OS is corrupt. Follow the manual and reload the OS, try the 2.43 OS
SOURCE: comma key on TI-84 Plus Siver Edition calculator.
The comma key on the TI 84 SE is above the 7 key, and it is just left of (, right of x squared, and below SIN. thats where the "," key is. If you're asking something else, please clearify. My understanding is that you don't know where the comma key is.
SOURCE: I can't graph on my ti-84 plus silv. edition
More than likely, you've put in a number in the xmin or xmax that is not correct. Example....you put in an xmin of 10 and an xmax of -10 which would be backwards. This could also happen in the ymin or y max.
The easiest way to fix this is to press zoom 6 which wil get you back to the default graph of xmin of -10, xmax of 10 and ymin of -10 and y max of 10.
If you can't see your graph on this screen and need to change the window, just be sure the number in the min for both x & y is smaller than the number in the max. You change your window size by pressing the window button.
SOURCE: How do i reset my
Beware that Ressetting RAM erases all data and programs from RAM. Archived applications and programs are not deleted.
You can also reset the Archives
