U-Line Icemaker Logo
Beverly Kezsbom Posted on May 25, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Unit gets cold but water pours thru without freezing. what could be the problem?
  • howard thompson May 26, 2015
    Hi Beverly Kezsbom, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? What is the model number?
Beto Flores
Level 2:
New Friend:
  • Expert 102 Answers
  • Posted on May 26, 2015
Beto Flores
Expert
Level 2:
New Friend:
Answers
102
Questions
0
Helped
64815
Points
165
Possible water valve leaking thru
1helpful
Hot water will not come down thru coffee
Your pour over coffee brewer has a reservoir that holds more than a pot of water. First thing you need to do is turn off the machine. Then put the empty coffee pot on the burner. Then take another container and fill it with fresh cold water and pour it slowly into the coffee maker until it starts to come out into the coffee pot. Stop pouring in water.
Now turn the machine on and let it heat up. Now you can brew normally. The reservoir has to be filled before you turn it on or you will end up eventually burning up the heating element.
WE ARE CURRENTLY IN NORTHERN TERRITORY VERY HOT AND HUMID. RUNNING AC THRU THE NIGHT IT STOPS BLOWING COLD AIR AND FAN SEEMS TO BE NOISY. HAS IT ICED UP DUE TO THE HUMIDITY. UNIT BEING RUN THRU THE DAY NO...
If your coil is freezing at night, it sounds like your getting cold enough at night to have your saturation temperature drop below the design of what the AC is able to do. If it runs all day without an issue and freezes up at night, you need to add what is called an outdoor fan cycling switch. This will turn the condenser fan off when the saturation temperature drops so it will not freeze your coil at night. You need to have an HVAC technician install this. It is not a DIY projuect since it has adjustments that need to be right. Plus, it it's a heat pump, it needs to drop the switch off in the winter.
1helpful
Sidebyside model 20-27 freezer drain hole freezes over
turn the refrigerator off and use warm to hot water to thaw out the ice at the drain hole. the drain hole may be frozen a couple inches below the top so make sure you use enough hot water to thaw it completely out. if you have a portable air tank you can then try blowing air thru the hole. or you can take a coat hanger or similar object to try and gently dislodge the obstruction. once you have the obstruction dis lodged you should be able to freely pour water thru the hole.
Water wont dispense but still makes ice. Also fridge side gets extremely cold no matter the settings and freezes stuff in the bottum drawers
Since your freezer control is the main thermostat , and your refrig control is only a damper , lower your freezer setting and turn the refrig control mid way . This will make the refrig run less , and keep the air flow moving , throughout the complete unit . When the airflow stops , by turning down the refrig control ( closing the damper ) , all the cold air will settle in the refrig section , thereby freezing everything in the lower section .
Since the water line runs thru the freezer door , too cold in the freezer section , will cause the water in the line to freeze . I would also suggest installing a dispensor heater ( pt. # WR49X10173 ) , which would hopefully avoid water line freeze , in the future . This part comes with installation instructions .
4helpful
2answers
No water in the ice maker
Pour about 2/3 cup of water into icemaker . If it freezes and dumps , and water doesn't go into icemaker , replace the water inlet valve ( the piece on the refrig that the wall waterline connects to . If it doesn't dump the water poured into it after freezing , then replace the icemaker .
1helpful
Rinse water barely trickles out of my washer
Do you fill the machine with hot water only?
If so, this is what I suspect. The filters in the inlet hoses on the back of the washer need cleaning. Remove the garden hose connectors, remove filter, clean, replace.
When filling with hot only you get a lot of pressure thru one hose. When you rinse, the best you can do pressure-wise is cold rinse -- but the cold water filter is going to be more clogged than the hot so it delivers less water.
When you use warm rinse, you get mediium pressure thru both lines, again less water than al hot on filling the machine.
Water/Coolant pours out of engine as soon as I put it in.
It has popped the freeze plugs out and you won't know the extent of the damage it has made till you replace the freeze plugs. You never i mean never pour water into a vehicle around time for freezing weather
5helpful
Kenmore Top Mount Refrigerator - leaking water from the Cold Control Defrost Timer/Automatic Defrost Control Housing
It freezes up for a few reasons. First the water is not running down fast enough. That is why the wire was added to add heat from the heater to the drain hole. The metal pan under the evaporator coil may not be lined up with the drain hole well enough and holding water there. If that looks ok the drain tube that runs down the inside back of the unit might be slightly restricted. Not much you can do about that. I would make sure that the aluminum wire goes in the hole about 2 inches and that the unit is tilted slightly back to help water flow.
Top U-Line Kitchen Appliances - Others Experts
ZJ Limited
ZJ Limited
john h
Are you an U-Line Kitchen Appliances - Other Expert? Answer questions, earn points and help others
