Try manually turning the developer drive gear on the Magenta imaging unit (use nose pliers)
_or_
Replace Magenta Imaging Unit.
Http://gethuman.com/contact/Konica-Minolta/more
800-456-5664
Konica Minolta Customer Service
callFirst call 800-456-5664; Press 0 OR Press 1, then 3 and then 1 then wait for the prompts
avg wait8 minscall hours24 hours, 7 days
800-456-6422
callFirst call 800-456-6422; Press 0
In general, help is available at this phone number for:customer problemssupportcustomer careissuesquestionsbillingsalescustomer service
Online Help
browseFirst go to https://wwws.konicaminolta.net/neoqa/gl/index.php; Online customer service support
In general, help is available at this help page for:customer problemssupportcustomer careissuesquestionsbillingsalescustomer service
877-778-2687
Konica Minolta Technical Support
callFirst call 877-778-2687; Press 4, then 1, 0#, 1
In general, help is available at this phone number for:tech supporttechnical supportbrokenfixtechnical problemsnot working
Thread Konica Minolta Biz C250 error c2553
Error Codes Konica Minolta bizhub C252 Code C2553
Code: C2553
Code
C2553
Description
Abnormally low toner density detected Magenta TCR Sensor
• TC ratio in the developing machine, which is determined by Toner replenishing amount control mechanism, is 5 % or less for a given number of times consecutively.
Remedy
1 Perform image troubleshooting procedure if image density is low. 2 Clean the TCR Sensor window on the underside of the Imaging Unit if dirty 3 M6, M7 operation check PWB-M CNDM2-10 to 13 (M6) PWB-M CNDM3-10 to 13 (M7) C-20 C-21. 4 Reinstall Imaging Unit. 5 Change Imaging Unit. 6 Change PWB-M. 7 Change PWB-MFP.
Toner hopar and toner senser
