HP Designjet T790 44-In Postscript Eprinter With Encrypted Hard Disk Logo
AN CUONG THINH Posted on May 15, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My HP Designjet T790 report "Error 21.2.:13, restart, if problem persists call support" i restarted but still can't print. Can you help me? Thanks
  • Mark Schmit
    Mark Schmit May 16, 2015
    The service station is on the right hand side not the left according to the manual.
  • Qasim Mousa Aljapory
    Qasim Mousa Aljapory Mar 19, 2019
    My HP Designjet T790 report "Error 8:12, restart, if problem persists call support" i restarted but still can't print. Can you help me? Thanks
Mark Schmit
Level 3:
  • HP Master 1,915 Answers
  • Posted on May 15, 2015
Mark Schmit
HP Master
Level 3:
Answers
1915
Questions
0
Helped
753222
Points
7967
This is a service station error. One of the more common causes I have come across is a piece of paper or foreign object jammed in the service station. It is located on the right hand side of the carriage. Unplug the plotter. Plug it in and the minute that you hear the print head move, unplug the power. Then open the window, move the head out of the way and look for a foreign object stuck in the service station.
  • AN CUONG THINH
    AN CUONG THINH May 15, 2015
    i think has a piece of pager jammed but i can't see it. When i open the window, head out of the way can't move. It's still left hand side corner. How do i can move head out of the way to look for a foreign object? Thanks
My HP Designjet 800ps gives the error 05:09,the problem is that is only possible introduce the serial number. Every time I restart the printer it gives the same error. Could someone please help me?
System error 05:09 (only applicable for Designjet 500 series) Formatter installed instead of HP-GL/2 accessory card. Turn the printer off and unplug the power cable from the back of the printer. ... If the problem persists, click on Support at the top of the page for additional HP support and contact options.
HP Designjet 500 and 800 Series Printers - System Error ...
videos and further help
https://www.google.com/search?q=HP+Designjet+800ps+gives+the+error+05%3A09
How to recovery Hp Designjet T790 24-in hard disk?
jeano: if you don't have the Recovery DVD, get with the Manufacturer of the hp Designjet, they will send it free (in warranty) with instructions. bigAl
Restore factory defaults
You usually need HP Webjetadmin 10.3 to do that.
Error se 36:01 hp designjet t790
If this error code was caused by a paper jam better could you tell what lead to this erro, unplug the power cable from the printer and clear the blockage. Open and remove the Clean out assembly from the printer and see if you have any particles left inside it. Plug in the power cable again and check if the Error Code has disappeared.
6helpful
Service Manual T790
hi.i have the code but i cant say that here.hp designjet t790 service menu code 09361002314 azad
We use hp T770 HDD, error massage 79.03 when loading, after show preparing print system massage in a few minutes. ask for restart but after restarted the problem persist. please kindly help us if there any...
79 errors are often linked to firmware. Unplug the printer from power as well as any network or USB cables you may have plugged in. If the printer will restart without an interface cable connected then it is likely a bad print job. Clear all jobs from the print queues and then plug in the interface cable. If printer continues to stay at ready, download the current firmware and install it. This should resolve the problem.
2answers
System error 010023 00000001
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Hope this help. Please Rate My Response! Thanks!
CF
6helpful
3answers
When I turn on my HP designjet T 1100 I get error message 08:11
turn off printer, disconect hdd from pcb, turn on then printer beeps, turn off mount hdd back, turno whait ;).
k24674
Grand Canyon Tech
Grand Canyon Tech
