There is a presser foot adjustment to reduce or increase the pressure. In your case, the pressure is probably too much and needs to be decreased. Some machines have a a round cylinder object projecting upwards surrounded by a around washer-looking piece of metal (usually on the top left side above the needle mechanism). Pressing on the washer-looking piece will cause the cylinder to pop up which releases the pressure. Then pressing down on the cylinder in gradual movements will increase the pressure. Check your manual. (When you are finished using your machine, you should release the pressure so the spring will not become compressed over time.)
