Carmella,
open the battery area and check the terminals,both may corroded
clean with emery paper and check it still not work check the dc motor connection the wires.still not move check ON/OFF button.
This bus will move.
with reagards.
jaijith
The days of electric vehicles having a rheostat speed control and huge switches to change motor direction are far behind us.
Most modern electric vehicles employ a good deal of electronics with a switch mode power supply for speed regulation which controls hefty semiconductor devices. The forward/reverse switch would typically engage/disengage either relays or more semiconductor devices.
These devices are often placed on a common circuit board and any problems will need specialist investigation, repair or replacements. It is most unwise to reverse battery polarity when electronics are present - it is likely by doing so you have increased the repair cost...
Possible electric clutch? If it is a clutch and has separate forward and reverse clutches, the forward clutch, control wire or clutch actuation magnet could be loose or bad. Good luck.
Amazon.com, Inc.Amazon.com: Lil' Rider FX 3 Wheel Battery Powered Bike, Black: Toys & Games. ...On Motorcycle 6V Toy Battery Powered Electric 3 Wheel Power Bicyle, Red ... VTechGo! ... sound effects, working chrome colored headlight, and forward and reverse ...power wheels vehicle more to handle size, weight, and your child won't ...
Amazon.com, Inc.Amazon.com: Lil' Rider FX 3 Wheel Battery Powered Bike, Blue: Toys & Games. ...Sold by: Global Supplies (We currently can't ship to, HI, AK,APO,FPO, POB) .... Ride On Motorcycle 6V Toy Battery Powered Electric 3 Wheel Power Bicyle, Red ... sound effects, working chrome colored headlight, and forward and reverse ...
your Husky is the nice old school machines. it has a friction wheel and plate that the wheel rides on for reverse and forward. rock the machine up on its auger and take the bottom plate off. move the forward /reverse lever and I'm sure it will be obvious what's not functioning with the friction wheel.
Try the friction wheel, you guys over think things. Use a snapper wheel, then use your original friction band, you'll have to modify the snapper wheel a bit but it will fix your problem
you need grease on your power shaft that has the forward/reverse this is where the power goes to the wheels slids back and forth A round wheel one side forward the other side reverse
I have a 6 volt battery power wheels car it has no reverse button the only button it has is just to make it go as I charge the battery it only goes in reverse don't know what to do that used to work fine it's at for a little while we charge the battery up and now it goes reverse instead of forward what should I do
