SOURCE: lights, horn, radio,stop/taillights, domelight nad
When you say "all fuses good" Does that mean the fuse panel on the passenger side end of dash...
and both power distribution boxes under the hood? They are attached to the fenders and you will have to remove the metal straps running over the covers to open them. Check power wire going to each box for tightness and 12 volts. If all the fuse's, relay's, and circuit breakers are good, you may have an issue with the "Body Control Module". You will find it under passenger side dash, behind the glove box. Might even be an issue with the ignition switch.
SOURCE: change backup light
well it depends on what type of car you have then i can help you out
If you need further help, I’m available over the phone at https://www.6ya.com/expert/michael_2094e122cc46f24c
no
reverse lights get power from a reversing switch and hove a separate circuit
check for correct bulbs in the holders as a duel contact bulb in a single point contact holder will short and blow fuses
