SOURCE: Reset
First, turn it on. Once the calculator is on, press the "2ND" key (I
believe it is a blue key in the ti-84 plus silver edition). Now press
the plus key (+). A little above that key, you should see the word
"mem." When you see the screen titled MEMORY, move the cursor all the
way down to the option that says "Reset." From here, you can choose to
reset either the RAM memory, or the factory settings. The factory
settings are the "Defaults" option. I hope this helps.
Thanks.
SOURCE: TI-84 Plus Calculator will not turn on, says ram is cleared
Thats because the OS is corrupt. Follow the manual and reload the OS, try the 2.43 OS
SOURCE: How do i reset my
Beware that Ressetting RAM erases all data and programs from RAM. Archived applications and programs are not deleted.
You can also reset the Archives
SOURCE: my TI-84 calculator says "Garbage
Found at www.epsstore.ti.com The reset procedure will delete all the items that are in the memory of the graphing calculator. Use the reset procedure below:
What can be done if a TI-83 Plus family or TI-84 Plus family calculator displays Garbage Collecting... for more than 20 minutes?
The garbage collection allows the cleanup of unused archive memory. It deletes unarchived variables from the user data archive and it rearranges the remaining variables into consecutive blocks. When a variable is unarchived, the Archive free memory amount increases immediately, but the space is not actually available until after the next garbage collection.
If garbage collecting is more than 20 minutes, the calculator has possibly locked up and will need to be reset.
• Remove 1 AAA battery.
• Press and hold down the [DEL] key.
• While holding down the [DEL] key, replace the AAA battery, and press the [ON] Key.
The message Waiting... Please install calculator software should appear. At this point, it will be necessary to reinstall the calculator's operating system.
• Connect the calculator to the computer using the TI Connectivity Cable or DirectUSB Cable.
Please post if this was helpful...
• In Windows®, click on Start >> Programs >> TI Tools >> TI Connect >> TI OS Downloader.
• In MacOS® X, open Hard Drive >> Applications >> TI Connect >> TI OS Restore.
• Follow the directions on screen to reinstall the calculator's operating system.
Access the link following for detailed instructions on how to complete operating system installation.
you have to run LinReg first, and then the option will show up
