In the bottom of the Breville Model BKC600XL there is a small glass check valve covered with foam. It is broken. Does anyone know where I can find one?
Before I start is there water in unit? If that inter tank is empty you willshort the heating element out.this is something like a elect hot water tank. you must have water in that tank. Also some time water leaksdown off a solenoid on to a transformer that also can short out.This is something that should be done by a pro. Hope this sheds some light on the problem. tvharry
It is SH-V0829BC-R(C1). The valve has leaked internally and prob shorted out. The needle valve didn't close completly when the water pump was running allowing water to enter the valve. Solenoid needs replaced. Krurig used this same item. can get the part on Ebay or do a web search and find a supplier.
mcdevito75 here, It may need to be cleaned, if the brewing holes are clogged it"ll signal coffeee maker to shut off. Refer to owner manual for cleaning.
