Computers & Internet Logo
A
Anonymous Posted on Mar 02, 2015
How do i dissable internal microphone
Asus x551m
Ekse
Level 3:
  • ASUS Master 13,435 Answers
  • Posted on Mar 02, 2015
Ekse
ASUS Master
Level 3:
Answers
13435
Questions
82
Helped
3985253
Points
38023
On the bottom right of your screen there is a speaker icon, right click on it and select recording devices, from there select the microphone and right click, select disable.
the microphone should now be disabled.
REPOST: Just reset start button by opening and removing and then reinstalling internal battery. Now it powers on, but keyboard does not work touchpad does work.
Try a hard reboot that sometimes fixes glitches including keyboard issues. To do this power down PC, unplug and remove battery. Then hold the power button down for 30 seconds, put battery back in and then plug the PC back in. Power up and see if keyboard works now.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/josh_8e641fe76e154b02
My asus x551m pc notebook wont charge or power up is there any way I can get it to work
I would first verify the power brick is putting out the correct amps and voltage. These values should be listed on the brick itself. You can test these with a multimeter. If the brick is working then your issue is either the DC jack on the motherboard or the motherboard itself and in both cases it is easiest to just replace the motherboard. You can probably find a board on amazon.com but just make sure it is for your model laptop.
Need the owners manual for a asus x551m
Asus has the manuals for many of their products on the product's support page. For the X551MA, start at https://www.asus.com/Notebooks/X551MA/HelpDesk/ . Click on the Manual & Document tab. The direct link to the English version of the manual is http://dlcdnet.asus.com/pub/ASUS/nb/X551MA/0409_E8717_X451_X551MA_B.pdf .
I hope this helps.
My asus notebook wont turn on X551M?
Try charging, replacing the battery
Asus X551M black screen after login
Reboot. Asus has problems at post. Also make sure it is charge. They are very slow to charge and if the battery is low will not always log on.
Need user manual for ASUS X551M
Asus X551MA User Manual for English Edition Page 115
here is the complete manual to this laptop i hope you find it useful
2answers
Why can I not turn on my Asus X551M netbook?
does it boot to cmos? what errors are you getting? is is totally dead?
I need more info, then i can help you.
Tony
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/tony_a41fa0b801734e2f
Why can I not turn on asus x551m netbook pc?
either a dead battery or a failed CPU / motherboard they would fail from a drop or from defects so i would recomend to take it in ONLY IF IT IS UNDER WARRANTY or else you might aswell buy a new laptop because it would be cheaper
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
