Need to reset hp 7410 semi reset
SOURCE: HP Officejet 6210 All In One inkjet printer reset types
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00060793
SOURCE: printer won't turn on
Well it just needs some good old TLC it just may need to be repaired if the reset did not work if its under warrenty hp will replace it give them a call you be glad you did.
Rulds2008
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
SOURCE: my hp 7410 printer wont stop booting up. how can I
on the printer front panel u will see a setup button .
it is denoted by a range . press that u will get all the options there.
but first disconnect the power chord from the back of the printer press the on button on the printer for 10 times connect the power chord back to the printer.
then try printing once
SOURCE: HP OfficeJet 7410 All-In-One InkJet Printer won't POST
Unplug the power cord from the back of the printer and while its unpluged, press and hold # 6 on the printer together for 30 secs and after 30 secs plug the power cable back into the printer while holding it and then after pluging it release the buttons after 6 secs
SOURCE: HP officejet 7410 all-in-one printer compatibility with Windows 7
Read the last comment on this blog about your printer. At the time that model was manufactured, Windows 7 was not apparantly listed or verified. I think they have updated their drivers, so update your drivers per the blog instructions. Good luck, hope this works for you!
http://social.answers.microsoft.com/Forums/en-US/GettingReadyforWindows7/thread/4f9cce97-ff84-44b9-a78e-eaa5fe4e9df7
