ASG Jergens 64281 A-5000 Driver with 2.0-11lbf.in Torque Electric Screwdriver Logo
v
valentin Posted on Feb 16, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to avoid wobbling in a torque screw driver
Wobbling alot
Kim Baker
Level 1:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 22 Answers
  • Posted on Jun 13, 2018
Kim Baker
Contributor
Level 1:
Welcome Back:
Answers
22
Questions
0
Helped
13580
Points
75
Mike
Level 2:
Habit-Forming:
New Friend:
  • Expert 46 Answers
  • Posted on Apr 28, 2017
Mike
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
46
Questions
0
Helped
15698
Points
135
Dimple the spot with a hammer and punch.
I have a 1993 suzuki katana 600, it has high km's. the valves make alot of noise, people say to do re torque the valves, would you know how tight I sould torque them too?
Either your friends are playing with you or they have no idea at all what they are talking about. There is no such thing as a re-torque of the valves. The valves are not screwed or bolted in place. How can you torque a screw or bolt that does not exist? The valve gap , aka valve lash, may need to be reset but no torque on the valves is possible. If resetting the valves, set the gap at .006 intake and .011 exhaust. There will be a lock nut, (not shown in diagram), on each of the adjuster screws. Your bike has two exhaust valves and two intake valves per cylinder. tombones49_184.gif
I have a hi speed front end wobble And just put a new front balanced tire and it still wobbles..
Did you line up the dot on tire with the valve stem ? if not break tire down and line up bal dot and re bal. If it is taking alot of weight try relocating tire on wheel until you find a better bal position that dont require alot of weight.
I have had new tires cause wobble , spin tire on bike and check for wobble in new tire.
3helpful
The passenger mirror on my 2003 Toyota 4 Runner wobbles. How can I tighten down the mirror on the base?
With my 4 runner, I had the same problem. All I needed to do was use a phillips head screw driver and tighten up a screw that is underneath the mirror housing. i.e. there is a screw hole on under side of the hosing for the mirror. Find that hole and tighten (it may seem tight already, but just give it a little bit more torque and see if that helps)
2helpful
2answers
Blade Slips Off
The two Wheels must be in line to each other, has one of the wheels moved? Does the missing screw clamp the wheel to the shaft? If yes you MUST replace the screw.
1helpful
2answers
Removing Chewed screw from Freelander Brake disc
Just a tip, you can avoid this problem in future, by using an impact driver, not expensive, and sold at most automotive stores, halfords, roadrunner etc. It impacts the stud, and twists at the same time, avoiding shredding the surface. It may still work on your stripped screw, if there is still some grip. It's a common problem on both the discs, and rear hubs on freelanders.
My washing machine feels level(doesn't wobble) but
I fastened my wife's washer to the wall with heavy wire inserted into 4 pieces of rubber attached to the wall and the wash machine. Rubber stoppers about one inch in diameter are held in place on the back of the washer about four inches below the top with copper pipe fasteners used to attach pipe to wood. These are on the back near each side and the ones on the wall are in matching locations. I used a 4" wide board on the wall so the screws could go into the studs and the stoppers could go where they were needed without concern about studs. The two pieces of heavy wire (not easily bent by hand) is bent into a U shape with a flat bottom and short legs. The width of the U depends on how far your machine is from the wall.The wire legs 2 - 4" long are then inserted down into the rubber with the bottom of the U upwards. Wherever you drill to attach the stoppers on the machine be sure to avoid any wires or mechanical components and I attached them near the top for ease of removal for maintenance-- which should be seldom. This solution has held my machine in place quietly for the last seven + years.
1helpful
2answers
2000 Hyundai Sonata front end wobbles.
put the front tires on the back and see if it changes.
alot of times,if the suspension is defective it wears the tires uneven ,out of round.
check and make sure the wheel nuts are tight and torqued properly.
alot of techs use just the gun,and not a torque stick and overtighten the wheel nuts.
Harmonic balancer
check the pulley if it wobbles alot replac it. or,
bolt may be comeing loose
put red locktight on the bolt adn torque it to 76 foot pounds
rank my solution &vote
2answers
Crib sturdyness
If it feels as though it wobbles, a likely problem is that the screws have not been fully tightened. They may feel tight, but give them all one good torque turn or two, until you cant anymore, pretty much. It should solve most of the wobble.
Top ASG Jergens Hand Tools Experts
john h
Larry Ng
Larry Ng
Ziyaad Khan
Ziyaad Khan
Level 1 Expert
Are you an ASG Jergens Hand Tool Expert? Answer questions, earn points and help others
