None othe these answer actually answer the question, the question is about a cometic issue. To the person who posted this this question have you figured out a way to fix it?
Pleas note that the dryer was running when this pic was taken.
SOURCE: Control panel locked light is on
ck for a button with hold to lock under it hold button 3-5 sec
SOURCE: Whirpool GGw9250Pw3 no power on Control Panel Inside light works
Hi.
Please read the Fixya article below explaining how to fix the problems related to control lock on Whirlpool dryers and washers.
The front light lit on my Whirlpool.
Regards.
SOURCE: dryer electrical supply ok but dryer control panel won't come on
If the contro lock is faulty the unit will not start. I think you have identified the problem there.
Please rate my help++++Thanks for using FIXYA
SOURCE: I have a Whirlpool Duet
Hello & Welcome to FixYa
As you have already tried cleaning the vent then the problem is with the Thermister which reads open and even the thermal fuse has continuity, also test the thermostat for continuity, the control board is fine it is this part that is causing the problem again and again. Please get back to me if you have any other questions.
Kevin
Mine is doing the exact same thing!
