Nothing. Can't find a way to get to the brush or wheels.
There are several reasons why your Shark is hard to bush.
1. The two front wheels are locked up or missing.
2.The suction force is too strong. Adjust the ring around the handle to reduce air flow.
3. The brush roller isn't working correctly.
4. Be sure wheels are not rubbing or stuck
They are not hard to push. You must have the rotating brush turned on. If it’s not on and your running it on carpet it will be hard to push. Check to see if it is spinning. You could have a broken belt
Does it have a "brushes" lowering/higher switch?
Normally due to brushes being too low in particular on deep pile carpets??
check the actual fixings for the rotating brushes are ok and the brush not simply need "clicking" back into place?
