Ok then eather it is you network adapter or you router it is conecting to. ALso this problem can occur if you do not have somthing set right like the netowrk password if conecting wirlessly. If this does not work then it may end up just getting a new one.
First off, if you can connect to the Internet ok then you really don't have a problem. There probably is another network card attached to your computer that is not configured correctly.
If you can't Get online then try this:
Go to control panel, network connections (something similar) and if the network card appears than right click and chose repair connection.
would check in device manager (control panel) and see if the network card is listed. It probably has a yellow exclamation point next to it. If there is an exclamation point there, then right click the card and click uninstall.
Somehow download the latest network card driver from the PC vendor website / Motherboard vendor site / discrete network card site.
Hope this helps
Brian
Yes it's connected mike_1151
It is enabled an connected mike .
is it enabled and the cable is conecsted to the router?
