Sony DVP-FX810 Portable DVD Player Logo
Posted on Jul 07, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When i plug in the charger to the dvd player it turns on, but the charget button doesnt. what do i do to charge it so i am able to use it without a charger
Anonymous
Level 3:
  • Master 10,594 Answers
  • Posted on Jul 07, 2009
Anonymous
Master
Level 3:
Answers
10594
Questions
9
Helped
2957524
Points
33084
Plug charger in player and switch it off when player turns on, then player will start charging attached battery pack.
  • Anonymous Jul 08, 2009
    You could ask further option instead of rating it bad. :)
1helpful
How to charge battery, is there a charger that we have lost or does it charge while on player & plugged in
The player charges, with or without playing a disc on it,
First step to charging your battery is having it plugged without playing it for a while.
There should be a light that comes on when you plug it to a power source.
When it is full, there also is another light that comes on to signify it is full.
You can also charge it while playing a DVD on it.
But if it does not charge when you plug it without playing a Disc on it, then there is a problem that need to be fixed on it.
test if the battery is charging.
  1. plug the player to a power source for some time,
  2. wait for some time for it to have charged very well,
  3. unplug it from the power source,
  4. test a disc on it to see if it will play.
if it does not play, then it means there is a problem.
which could be that the battery may be faulty.
All you have to do is to replace the battery and it will work perfectly fine again.
take care
7helpful
2answers
I have a accurian portable dvd player APD-3955 and it works but the charger doesnt charge it anymore. Now the battery died and I was wondering if it just needs a new charger. I got it June 2008.
I had the same problem and I found out that is definitely the battery. I had used mine only a few counted times and after 1 year the battery would not charge. I would plug it and the charge light would turn on and stayed for about 4 minutes and then turned off. I called axion and talk to customer support. The tech said that the internal batteries only last for a year whether you use the DVD or not. They would replace the battery for $60 + shipping costs. As you can see... it is not worth it....sometimes you are lucky and get good stuff for cheap but sometimes... you just get what you pay for.... and this is one of the cases. Yes, I am also very disapponted. What a piece of junk!!!! I can still watch DVD with either the charger plugged in or with the car charger. But it lost its Portable side.....
2helpful
2answers
Charging light not coming on
Good day sir, my guess is that your adapter is the culprit, if you have access to another charger please use it, if you may have the time, try to visit your dealer, and they be wiling to test your adapter. Other causes may be the charger DC port, or the battery, but let us stick first to the common adapter problem, hope this helps.
1helpful
Can't seem to get my dvd player to charge.
I have this model dvd player and it has worked very well for over a year. Lately it has not had a picture but has had sound when fully charged. When the green light is on, it is charging. When the light goes off, it is fully charged (or should be). I plugged the wall charger directly into the dvd player and it works fine with pic and sound. I think maybe the rechargable battery is on it last legs. I am looking for a longer cig lighter charger cord to reach the headrest so kids can watch from backseat. I will be able to keep it plugged in to charger at all times. Hope this helps!
1helpful
Mintek 8" TFT portable dvd player MDP1810
DO NOT continue to try to charge that battery. The company recalled those batteries because they explode or start on fire. Do a google search of "mintek" and you can read about the recall.
CHARGING
Lulu1121 and guest, red means no charge and will remain red till its fully charge. Then it will turn to green. In fact, coby battery can be charge directly without the whole unit attached. But if on charge too long and still red, battery is dead, kaput, finish. some even show evidence when the casing is swollen...gel chemicals inside is swollen. The power supply that came with it is the only way you can use it...portability is out of the question.
Good Luck
Siliconchip
2answers
Charge light does not come on???
I had the same problem after buying a new dvd from bestbuy.
although this may sound wierd, but check if you have a battery in there, since its coming without it inside.
maybe you bought it without a battery.
1helpful
3answers
My Mustex MP-100
my mp100 mustek player will not switch on or charge up also it will not switch on when the mains charger is plugged in. the light on the charger went out and will not come on anymore.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
