JVC AV-48WP74 48" Rear Projection HDTV-Ready Television Logo
Posted on Jul 07, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Jvc AV-48WP74 i no its a convergen issue but..
The colors are all wack. at the top of the screen the red, blue, and green colors swoop down and on the bottom the color curves going up and the bottom is black
Sonny Berry
Level 3:
  • JVC Master 8,617 Answers
  • Posted on Jul 09, 2009
Sonny Berry
JVC Master
Level 3:
Answers
8617
Questions
Helped
1722980
Points
23750
You can get the convergence repair kit at the following link which usually fixes that issue. The kit contains the parts and detailed instructions on CD of how to do the repair.
http://www.tvrepairkits.net/
JVC AV-48WP74 BLUE CONVERGENCE ADJUSTMENT PROBLEM
Make sure you bought genuine Sanyo chips...if not goto www.TvRepairKits.com and get theirs.
Jvc av-48wp74 48 in widescreen green projector problem
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
JVC MODEL AV-48WP74
Convergence Issues Both STK392-110 ICs and possibly the 1.8 ohm and 1.5 ohm 1 watt convergence resistors as well. You can get replacement parts at the following link and they provide free instalation instructions
http://servicemanuals.vstore.ca/
JVC AV-48WP74 only has green color
Have a shop look at it. you cant fix it at home. really.
Jvc av-48wp74 48 in.rear
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Red will not converge with the other colors
the problem is that you neglected to replace the open (hope you replaced both stk's) and replaced the green pico fuses
JVC 48WP74 HDTC rear projection
While it is true JVC tubes rarely fail, they can give trouble.
Another possible solution is bad screen / focus block......
Remove lower front grill panel and access board...Check for
smooth adjustment of RGB screen and focus.....let me know....T..
MY TV!!
try using AV im puts with dvd or vcr if this work your tuner is bad new cost aruond $90 to 120 if available but next year you wont have use for it
JVC AV-48wp74 Red, Blue, Green
no you did the right move but now you align the new pc board ,try to get the service in to enter the convergence alignment section,on most jvc;s it sleep timer ,disply&video status to enter try it but if your not sure of that you can perform the alignment ask a tech to do it. on the remote certain keys do special functions and you need to know what they do or you might make it worse.
2helpful
3answers
JVC MODEL # AV-48WP74 48 IN. BIGSCREEN TV.
I had a problem with my TV colors not lining up. One day I turned it on and the green was out of wack. I checked this message board and replaced the STK chips, bad soldering and all led to me just giving up on that and buying a whole new Convergence Board ($185). I just plugged this in and though now my Green lines up okay, my red is out of whack. Is there something I am doing wrong? Can anyone help me? Did i miss a step? Frustrated......Bruce
Top JVC Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
 Grubhead
Grubhead
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
