Different types and quantities of detergent
SOURCE: My Maytag Front Loading Washer Does Not Fully Rinse Cloths MAH8700A
A friend had this problem and was ready to buy a new machine. Sometimes it worked and sometimes not. I took a last look before new machine and found a coin that would intermittently block the pump/discharge port on the machine.
SOURCE: Whirlpool Duet Front Load Washer
do a vinegar flush Pour a quart of distilled vinegar into your washer and using Hot water wash let your machine run through a wash and rinse cycle. The vinegar will cut through suds .. also wipe down the rubber gasket with a 1/2 vinegar /water solution to clean the gasket
SOURCE: Clothes come out extremly wrinkled on top loding whirlpool washer
This is normal. You can try a lower spin setting or smaller loads. The wrinkles will come out in your dryer.
SOURCE: What does F- indicate?
The SD code, is a sudsing code. If you are using the appropriate amount of soap and HE soap, it could be a communication error with the sensor and the CCU (the main control board). If you take off the panel on the bottom of the front (3 screws on the bottom hold it on). Once you get in, there is a plastic pouch on the right hand side there is a tech sheet that will have a list of all the error codes, and what to check.
Good luck
SOURCE: I have a Whirlpool Duet washer WFW9500TW.
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$$$$
