My machine is konica minolta c252 my touch screen dont show any thing and havent light its hust black screen and i changed cable also not fixed pleas any one can help what is way for solve
www.fixya.com > Forum > Printers & Copiers > Konica Minolta
Konica Minolta BizHub C252 - pale colors on the long side · Konica Minolta. ... I have a Konica C250 machine which cannot print red color at all. I had changed ...
www.fixyourownprinter.com/posts/40820
Aug 22, 2008 - On the right hand side of the drum (the part that has the large green handle) that easily slides out. There is a ..... I have konica minolta bizhub c252 colour printer. ... The K light came on a long time ago and is constant on now.
? 0:28
https://www.youtube.com/watch?v=eD8HdNq0MlE
Nov 23, 2011 - Uploaded by Tennants Nottingham
How to clean the drums/i units on the konica minolta number plate printer ... Fix or repair color laser printer with fading, lightprint, or lines samsung clp 300 ... Imaging Unit Reset for Konica Minolta Bizhub C203 / C253 / C353
To get to the network settings: Press the Utility/Counter key, select Administrator Settings, enter 12345678 as the password, then select network settings. You will find all the settings for networking the machine there. The print drivers can be downloaded from Konica's web site: kmbs.konicaminolta.us
User manuals can be found there as well.
Black Screen
When you turn the machine ON, if there is no display on the control screen and also there is no sound of warming up, then the problem is with the Print Conrol Board, (Main Mother Board) replace it and your problem is solved.Before doing that you can try replacing the RAMs.
Secondly, If you hear machine's normal warming up rotation sound and there is no display on the screen then please check the Display Cable, white VGA like cable connected with the control panel.Check, it may be loose or not properly connected.
sounds like the sleep timer is activating before the boot is finished try touching the screen and then switch the timer up or if it networked go to the machine web page and turn the timers up from there then try again
magenta toner cartridge EEPROM access error, cleaned the connection between the toner cartridge and the machine once cleaned if the issue persists remove the toner cartridge and put back in again if again the error persists replace the toner cartridge with a new one and last resort if the issue is still not fixed then replace the mechanical control board.
